front coil springs
Hope u guys can help
My Octavia vrs recently failed the MOT due to both front coil springs being fractured so i booked it in at local back street garage
picked it up yesterday and the front end ie clearance between arch and wheel seems to be higher is it possible they got wrong part and put on standard octavia springs
cheers
ask where they got the springs from - vRS ones are dealer or TPS only
Very likely. If I recall correctly, vrs springs are dealer only. Ask them where they source the springs and don't take any carp! Insist that they source the correct springs and fit them foc.
so can standard springs actually fit on?
and will it effect performance? or are safe?
Edited by jonnymk1vrs
To answer your questions, Yes and Possibly Not.
You'll not be the first vrs owner to be given standard springs and I guess you won't be the last either.
It's got to affect ride height and handling. Depends on your driving style I guess. The fact that you've noticed a difference suggests something isn't right.
does anybody know the correct ride height for a vrs and where you measure from and too
As said. If the springs havent got the yellow and purple dots on they are the wrong ones. Take it back.
I've had the torch out and from what i can see of the coil i cannot see any markings just the black coil
As above :)
For the VRS it's 1 violet and 4 yellow paint marks
As they can only get the VRS springs from dealer/TPS, they will have fitted springs designed for the 1.9 TDi. You could use these if you changed the dampers as well, but in doing so you lose the 'sports handling' of the VRS
As already stated correct VRS springs are main dealer or TPS only, no if's or but's. Ask your garage where they sourced the springs from. Standard springs will fit, but will give the wrong ride height, & poor handling.
