Urgent!!!! - Help Please
Looks a little too low \ needs bigger wheels IMO...
if its too low what can it damage or wear prematurely?? might be a little low as it was setup up for stuarts which is a hatch so surely mine has a little extra weight on the back. might play with it a bit now that i have more time/light today
  • Administrators
Looks low because it's weight is on the road side...it's on a kerb...
Mine was slighlty below RS height and once alinged I did not have adverse tyre wear....a trip to the powerstation was always planned, but I sold it instead.
just thinking in the KW paper work there was a small bit of text that suggests to swap the upper and lower arms on the rear suspension if the camber is more than 3 degrees, it suggests that it may get it to around 1.15 degrees. don't know if this would work for the octavia 4x4 as the instructions were also for the s3, a3, golf and leon
offtopic/
colin, is your avatar from topgun?
offtopic/
colin' date=' is your avatar from topgun?[/quote']
Looks like 'The Rock' to me when he lights the flares at the end.
here's a good man to ask, Ross what ya think about swapping the upper and lower rear arms on the 4x4 to correct the camber? i don't know myself i just read it in the kw bumph
I'll check the part numbers but im pretty sure on the Audi TT ans S3 (we did a recall sometime ago on them changing the arms) all four were exactly the same.
interesting, not saying your wrong or anything mate just confused why they would put that. gonna go check what says now, it may turn that i am stupid with a bad memory(probably :rolleyes: )
I'll have a look on our parts computer at ork tomorrow to be sure. Could well be the Octy is different anyhow for some reason.
  • Administrators
Yup...trying to save the prision from destruction, lighting the flares to show he's done the job...the rock.
oh well, at least the films were similar :rolleyes:
never seen the rock btw but top gun is great
