Fabia DRL (running lights) Help please
Thanks. That's a pretty good glossary.
I saw raymo's thread asking about SMD but didn't know it meant. Thanks to this thread I now do. The photos of his setup don't look too harsh, but I suspect that they might be more noticeable in the flesh - I know that's the idea.
I suppose my ideal compromise would be a "soft" effect a bit like the diffused backlighting used in the overhead menus in fast-food outlets. Or even the white background of this page on my tablet.
  • Replies 141
  • Views 28.5k
  • Here is a quick pic of my new sidelights. What do you think?
  • The true watt of a 5 watt-diode is 5 watt. They are however not pushing 5 watt through each diode, it's 1 watt in those lamps. False advertising is what it's called . I should know, I work with LED
  • I haven't seen them in full daylight yet, only put them in tonight when I got home from work. They seem to be brighter and emit light from the side of the bulb too so it makes use of the reflective ho
Definitely no switch for DRLs on the Reaction. I assume that's what fills the hole that I have directly to the left of the OBD2 port and before the fuse array. Fuse 17 (top right) does the job nicely.
I like my new DRL's (LED) but is anyone else getting monumentally p****d off with people thinking they are fogs |: they look nice I refuse to take them out! :P
I know it is not time for your MOT but if you took it for one it would fail as every light has to work  ;)
Thanks. I'll have to check up on that, but have plenty of time.
I wonder if lights must work if they have bulbs in and removal of the bulbs would hypothetically bypass the issue. Its not as if a switch is there to hint at their presence.
I'm shortly to take another car for MOT which lost a fog light (glass anyway) in a recent pheasant strike. I've not found a replacement and the light has been "mended" with opaque/stripey duct tape. If the bulb still works, I'm sure its heat will melt the tape but given that I might use front fogs one day a year it shouldn't matter if I can find one at a breaker's. They're rare as hens' teeth.
That's great Fab! Glad you are so happy. ...I know I am. Still haven't bitten the bullet and done the fog lights though..... not sure if it's worth the money for the amount of time I would use them, plus I have the awesome HID conversion. Rapid. .....im my opinion LEDs look a little 'star trek' & 'cheap' behind the lens when off. ..This is the kind of bulb I would go for if subtle is your bag http://www.ebay.co.uk/itm/281064869868?redirect=mobile As compared to these which I don't like the look of when off. ..http://www.ebay.co.uk/itm/2X-1156-BA15S-382-P21W-White-50-SMD-LED-Tail-Brake-Turn-Signal-Light-Lamp-Bulb/281155994953?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D74%26meid%3D1754762858407717159%26pid%3D100005%26prg%3D1048%26rk%3D1%26rkt%3D4%26sd%3D281115364101%26 Sent from my GT-N7105 using Tapatalk 4
I'm fancying a set of the first ones in this post but I'm a little concerned that they might throw up error codes with only having 1 x Cree fitted to each bulb, I know you can fit extra resistors but didn't really want to start messing and spending even more money on them, any thoughts on if these will work or am I best just getting the same as a few others on here that has the 2 x 5w Cree in each bulb that are tried and tested and work fine ??? PS I don't want them to be really really bright ;-)
I've not tried the bulbs with the single chip in them. I have to say that one of my bulbs stopped working for some reason, the only way I knew was I noticed the reflection in a window, anyway I didn't get an error message on the dash so not sure if they are monitored. A lot of it us down to the power draw and the unit flickering but I don't think it will be a problem. I put 7w CREE single chips in the fogs with no bother, changed them for 30w CREE and still no bother so I think you should be ok......can't he 100% though. 5w is pretty bright and in all honesty I wouldn't say the 10w look twice as bright if that makes sense.
Hi jono any chance of a couple of pics of your 30w crees in situ. cheers
Just as clarification : there is no TRUE 30w CREE-bulbs for DRL/fog-lights.
Those replacementbulbs are at their strongest 10w... And those are the ones that are rated "80w"!
What is the 'true' wattage of a 5watt CREE chip? If the unit has 6 x 5W chips what is that?
I guess it would make more sense to talk about the light output in lumens then?
I wonder jonro would they be that bright that they would p1ss other drivers off ....i really would love a set .road-rage-smiley-emoticon.gif
I'm guessing they probably would be pretty bright. They do the same bulb in H7 and as a work light for a roof bar so I reckon the output would be too much......mind you I would be on the right side of the lights so :unsure:B)
False advertising is what it's called ;).
I should know, I work with LED.
Regarding the "80 watt" (10 watt) lamps, those are NOT too bright imo.
They develop around 700 true lumen, which is around what you find in DRL-lights usually.
The "30 watt" is declared to develop 800 lumen, but the real figure is around 500 lumen.
As I stated earlier : I work with this 24/7, so if there is any questions just ask and I'll try to answer and help out =).
EDIT : the "80 watt"-lamps are not CANBUS-approved.
A replacementlamp for ba15s is truly CANBUS-approved when you can have it replace indicators.
And that lamp is not capable of that in cars that have CANBUS on indicators ;).
EDIT 2 : they do work for DRL since there is no CANBUS there.
They work really well for brakelights and reverselights aswell ;).
EDIT 3 : this picture shows how bright those bulbs are in an old BMW 5-series.
Old reflectors and glass which is not clear, still impressive how much that comes out ;)!
https://www.facebook.com/photo.php?fbid=613127008751038&set=pb.551738064889933.-2207520000.1385837937.&type=3&theater
Edited by Confide
I might pick your brains one day then. I didn't think the DRL had CANBUS monitoring. Are the '80w' bulbs really not to bright?
I see no BMW....
This has only increased my desire for them now!
Yes, they are a big-seller here in Sweden!
After all, it gets dark here early and it gets worse the further up the country you come =).
In the most northern parts, the sun doesn't even come up for 1 hour a day some days...
But yes, the desire is understandable ;).
After all, they are my big-seller in replacementbulbs for cars (no, I'm not the Ebay- seller =) ).
Why would you want brighter 'Day Time' or 'Day Light Running lights' if it is mostly dark ,
do you not just use the cars headlights.?
george
Replacementbulbs for reversing, George ;).
Read the earlier post :D!
I have just fitted 80w CREE DRL'S they look the business. They have 4 forward facing chips and 4 lots of 3 outward facing chips which reflect off the housing really well to give a good light emission from side on unlike the 10w bulbs I had
I have just fitted 80w CREE DRL'S they look the business. They have 4 forward facing chips and 4 lots of 3 outward facing chips which reflect off the housing really well to give a good light emission from side on unlike the 10w bulbs I hadSent from my GT-N7105 using Tapatalk
Do you have any pictures? Trying to decide which ones to buy for my upcoming monte :)
I will get some sorted tomorrow. In the dark they are very bright so don't really show their daylight potential. At £35 they aren't cheap though!
Jonro - how do these Cree's compare to the £22 ones you'd previously recommended? (and which I bought and installed into my Fabia).
Edited by FabFabFabia
