oil catch tank !
What size pipe is that mate, ID ??
I assume you mean stainless steel? As steel probably will oxidise and bits will start flaking off emoticon-0124-worried.gif
I didnt pipe it back into the intake, instead I vented it off using a breather filter.
Nothing internal should be green so its probably something from what you've put in emoticon-0143-smirk.gif
I did this -
I've added a couple more stainless steel balls (now fairly tightly packed), an oil level indicator and a breather filter.
It's 19mm you need.
I bought a bit off eBay that's doing the trick ... Item number 230977571103
It says 3/4" on the hose.
It's 19mm you need.
SNAP!
SNAP!
Touché :thumbup:
