LIGHTS?
byte18 you don't check or uncheck you type a hex value into it, you'd know if modified it so if you haven't that's good.
Hex value .?
For what the drls ?
This is something new ... Haven't heard about this before .!
No leave it alone trust me!
If you haven't modified it then it aint the reason your DRL's have failed!!!
Forgetting about your DRL's for a moment have you checked the tail lights in question? The maxidot is reporting they are out, so are they out?
Ya they are .....!
And it correctly says both the side lights in the tail lights are out .!
So let's say even with these clever canbus systems our Octy's have.....
Let's say the circuit spiked and wiped all 4 bulbs are out that being 2 tails and DRL's. (not worrying about no warning for DRL)
So change your tail bulbs so all 4 each side are working then see what the maxidot says.
Total 6 bulbs have gone ( including drls)
There are two in the side lights on each side .!
Assuming the circuit has been spiked ...am I looking at a huge bill ?
Also should I try changing the drl bulbs also ??
