DRL's 'lost'
I've been trying to find a way to do this (as well as get the instrument cluster to light up during the day without the side/headlights on) on the vRS but to no avail.
I had the dealer code front AND rear DRL's at the same time (option was "tail lights on with DRL's" on VAS) , if we could find a model exactly the same as mine without this coded we could work out which bit / byte VAS changed.
can we email Ross tech support on this & the issue with dash illumination on all the time? do they help with things like this?
Yes, send them a full scan of the car and they will look into it, hopefully when the next software update is released there will an inclusion for this.
I'd like my instruments lit all the time too.
Paul
Does anyone know what the byte is for a 2010 Octavia with separate bulbs in the foglights? I think I tried 30-39 to no avail. Just can't get them to light up!
same problem I've changed byte 18 in my Skoda Octavia 2012 (facelift or fantasia) with a bcm module from 00 to 7F and can't get it back to it's original code (00 is not the original code it's a hidden code), so if any one knows the factory code for byte 18 please post it
  • 4 months later...
Finally sorted using the VAS 5052 system at work ! :giggle:
Only took 2 years..............................
  • 2 years later...
Thanks, but if you read the whole thread you will see in post #2 that I found out the code was 31 a few days after I posted this (June last year)
If you know of a code to get DRL's front AND rear for a RHD car with xenon's then that would be useful emoticon-0148-yes.gif
Welcome to Briskoda anyway.
Hi everybody!
Gizmo68 can you find out what is the correct coding for use DRL with the rear parking lights together?
My car is also Superb Combi with Xenon and separeted DRL from 2011.
I saw there is a coding for LED DRL with rear parking lights and when I changed byte 18 from list the DRL 's gone. After with this option, the front and rear parkinglight starts working like before the coding.
Now I set back byte 18 for code 31, and this LED DRL function not works again. I hoped that the DRL can work together with the all parking lights ,but this way was also a dead end.
Edited by becza2
Hi everybody!
There might not be a correct byte 18 value for your car. If the factory code was 00, then the lighting configuration was read from a section of eeprom that VCDS can't access. It also means that by changing byte 18 you have lost this original configuration permanently.
You need to find someone with either VCP or ODIS-e that knows what they are doing. They should be able to restore the original functionally and also enable rear lights with DRL.
After the 31 codeing all the functions now like before. Only this rear lights not working with the DRL together. This is the original setup of the car. The newest model with LED DRL can work together, If I like I can switch ON/OFF with the VagCom.  Maybe this functions is not working with this model, because I didn't find anyone who posted it's working. Just only if the car have rear LED lights no matters witch model Octavia or Fabia.
I never found a code to turn the rear lights on with the front DRL’s
Excellent, to confirm the cars default byte 18 was 31 and by setting it back to 31 everything is working as it should.
As you've not posted an autoscan, I guessing you have a 1K0937087AN fitted. If this is the case you can get rear DRL working if you find someone with VCP or ODIS-e to alter the lighting configuration after setting byte 18 to 00.
Maybe this help for somebody.... But my car only wworks with 31 coding :(
ch habe hier mal eine liste was byte 18 alles kann.
VW xxx ausgewähltes Fzg EEPROM 0
BCM Default ROM 1
VW360 Halogen VW360 RdW TFL_0 ROM 2
VW360 Halogen VW360 NAR TFL_0 ROM 3
VW360 GTI Halogen "VW360 RdW TFL_0_LED + LED_SBBR" ROM 4
VW351 Halogen VW351 RdW TFL_0 ROM 5
VW351 Halogen VW351 NAR TFL_0 ROM 6
VW351C Halogen VW351 CHN TFL_0 ROM 7
VW362 Halogen VW362 RdW TFL_0 ROM 8
VW362 Halogen VW362 NAR TFL_0 ROM 9
VW364 LL Halogen VW364 RdW TFL_0 LL ROM 10
VW364 RL Halogen VW364 RdW TFL_0 RL ROM 11
VW367 Halogen VN337 RdW TFL_0 ROM 12
VW368 Halogen VN337 RdW TFL_0_Ska ROM 13
VW369 Halogen VW369 RdW TFL_0 ROM 14
SE350/2 Xenon XENON SE352/7 NAR TFL_0 XE ROM 15
SE351/9 Xenon XENON SE351/9 NAR TFL_0 XE ROM 16
SE350/2 Halogen Halogen SE352/7 NAR TFL_S ROM 17
SE351/9 Halogen Halogen SE351/9 NAR TFL_S ROM 18
VW428 Halogen VW428 RdW TFL_1 ROM 19
VW428 XENON VW428 RdW TFL_1 XE ROM 20
VW360 GTI Halogen "VW360 RdW TFL_0 +LED SBBR" ROM 21
SE350/2 Xenon XENON SE352/7 RdW TFL_0 XE ROM 22
SE351/9 Xenon XENON SE351/9 RdW TFL_0 XE ROM 23
SE350/2 Halogen Halogen SE352/7 RdW TFL_S ROM 24
SE351/9 Halogen Halogen SE351/9 RdW TFL_S ROM 25
Halogen SK462 ohneTFL / TFL-ABL ROM 26
SK461 Halogen SK461 ohne TFL / TFL-ABL ROM 27
SK461 Halogen SK461 RdW sep.TFL_1 ROM 28
SK461 XENON SK356 ASUV TFL_Sep ROM 29
VW360 Halogen "VW351 NAR TFL_0 + SMR auf SL-hinten " ROM 30
VW360 Halogen "VW360 NAR TFL_0+LED SBBR" ROM 31
VW360 Halogen VW360 NAR TFL_0_LED ROM 32
VW360 Halogen "VW360 NAR TFL_0_LED+LED_SBBR" ROM 33
VW360 Halogen "VW360 RdW/Japan+LED_SBBR" ROM 34
AU350PA Halogen "VW360 NAR TFL_0_LED+LED_SBBR" ROM 35
AU350PA Halogen VW362 RdW TFL_1 ROM 36
AU350PA Halogen VW364 RdW TFL_0 LL_Ska ROM 37
AU350PA XENON VW364 RdW TFL_0 RL_Ska ROM 38
AU350PA XENON VW316 RdW TFL_1_Ska ROM 39
AU350PA XENON VW465 RdW TFL_1_Ska ROM 40
AU353PA Halogen VW362 RdW TFL_0_Ska ROM 41
AU353PA Halogen "TFL mit Heck, AB2 PA 5Türer ECE" ROM 42
AU353PA XENON "LED TFL ohne Heck, AB2 PA 5Türer ECE" ROM 43
AU353PA XENON "LED TFL mit Heck, AB2 PA 5Türer ECE" ROM 44
AU356PA Halogen AU356PA RdW TFL_0 ROM 45
AU356PA XENON AU356PA RdW TFL_0 XE ROM 46
VW316 Halogen/XENON VW316 RdW TFL_0 ROM 47
VW316 XENON Halogen/XENON VW316 RdW TFL_S ROM 48
SK462 Halogen SK462 separat TFL_1 ROM 49
SK350 Halogen SK35x-RS TFL_LED-RL aus TFL ROM 50
SK350 Halogen SK35x-RS TFL_LED-LL aus TFL ROM 51
SK350 Halogen SK351 TFL_1sep. RL aus TFL ROM 52
SK350 Halogen SK351 TFL_1.sep LL ausTFL ROM 53
SK350 Halogen SK351 RL TFL-ABL(S) ROM 54
SK350 Halogen SK351 LL TFL-ABL(S) ROM 55
SK350 Halogen SK351 TFL_SH RL ROM 56
SK350 Halogen SK351 TFL_SH LL ROM 57
AU210 Halogen VW364 RdW TFL_S LL ROM 58
entfallen XENON VW364 RdW TFL_S RL ROM 59
VW360 XENON VW360 RdW XE TFL_S ROM 60
VW360 XENON VW360 NAR XE TFL_S ROM 61
VW360 Halogen VW360 NAR ROM 62
VW360 XENON "VW360 Ska XE TFL_S LED_SBBR" ROM 63
VW360 Halogen VW360 RdW ROM 64
VW360 XENON VW360 RdW XE PO_LED ROM 65
VW360 XENON VW360 Ska XE TFL_S_LED ROM 66
VW360 Halogen "VW360 Ska TFL_S LED_SBBR" ROM 67
VW360 XENON "VW360 RdW XE LED_SBBR" ROM 68
VW360 Halogen VW360 Ska TFL_0_S ROM 69
VW369 Halogen VW369 Ska TFL_0_S ROM 70
VW369 XENON VW369 RdW XE PO_LED ROM 71
VW369 XENON VW369 RdW XE TFL_LED ROM 72
VW369 Halogen VW369 Ska TFL_S ROM 73
VW351 XENON VW351 RdW XE PO_LED ROM 74
VW351 XENON VW351 RdW TFL _LED ROM 75
VW351 XENON VW351 NAR TFL _LED ROM 76
VW362 XENON VW362 RdW XE PO_LED ROM 77
VW362 XENON VW362 RdW XE TFL_LED ROM 78
VW362 XENON VW362 NAR XE TFL_LED ROM 79
VW316 Halogen/XENON VW316 NAR TFL_1 ROM 80
VW316 Halogen/XENON VW316 NAR TFL_S ROM 81
VW465 Halogen/XENON VW465 RdW TFL_1 ROM 82
VW465 Halogen/XENON VW465 NAR TFL_1 ROM 83
VW465 Halogen/XENON VW465 RdW TFL_S ROM 84
VW465 Halogen/XENON VW465 NAR TFL_S ROM 85
AU354 Halogen VW465 RdW TFL_S 2R ROM 86
AU354 Halogen VW465 NAR TFL_S_II ROM 87
AU354 XENON "AU354 TT NF LED TFL+Choming H SL" ROM 88
AU354 XENON "AU354 TT NF LED TFL+POL+SL+KZL+Choming H SL" ROM 89
SK35x Halogen/XENON SK35x-RS-RL TFL-LED aus Shutter ROM 90
SK35x Halogen/XENON SK35x-RS-LL TFL-LED aus Shutter ROM 91
VW465 FL Halogen "VW465FL RdW TFL_1 8TA" ROM 92
VW465 FL XENON "VW465FL RdW TFL_1_LED 8TA" ROM 93
VW465 FL Halogen "VW465FL RdW TFL_1 8TC_8TD" ROM 94
VW465 FL XENON "VW465FL RdW TFL_1_LED 8TC_8TD" ROM 95
VW465 FL Halogen "VW465FL NAR TFL_1 8TA" ROM 96
VW465 FL XENON "VW465FL NAR TFL_1_LED 8TA" ROM 97
VW465 FL Halogen "VW465FL RdW TFL_1_Ska 8TC_8TD" ROM 98
VW465 FL XENON "VW465FL RdW TFL_1_LED_Ska 8TC_8TD" ROM 99
R8 Halogen/XENON "LED TFL ohne Heck, R8 ECE" ROM 100
R8 Halogen/XENON "LED TFL mit Heck, R8 ECE" ROM 101
R8 USA (SM 0W)" ROM 102
R8 USA (SM 0W)" ROM 103
R8 Halogen/XENON "Komplett LED, LED TFL o. Heck, R8 ECE " ROM 104
R8 Halogen/XENON "Komplett LED, LED TFL m. Heck, R8 ECE" ROM 105
R8 Halogen/XENON "Komplett LED, LED TFL ohne Heck,
R8 USA (SM 0W)" ROM 106
R8 Halogen/XENON "Komplett LED, LED TFL mit Heck,
R8 USA (SM 0W)" ROM 107
AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ Bulb 8.08.08 " ROM 108
AU210 Halogen/XENON "TFL mit Heck, AU210 Halogen/ Bulb 8.08.08 " ROM 109
AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ LED 8.08.08 " ROM 110
AU210 Halogen/XENON "TFL mit Heck, AU210 Halogen/ LED 8.08.08 " ROM 111
AU210 Halogen/XENON "TFL ohne Heck, AU210 LED TFL/ Bulb 8.08.08 " ROM 112
AU210 Halogen/XENON "TFL mit Heck, AU210 LED TFL/ Bulb 8.08.08 " ROM 113
AU210 Halogen/XENON "TFL ohne Heck, AU210 LED TFL/ LED 8.08.08 " ROM 114
AU210 Halogen/XENON "TFL mit Heck, AU210 LED TFL/ LED 8.08.08 " ROM 115
SK461 China Halogen/XENON "SK461-China ohne TFL SL mit BL-Funktion LED SBBR" ROM 116
SK461 China Halogen/XENON "SK461-China ohne TFL/TFL-ABL SL ohne BL-Funktion LED SBBR" ROM 117
AU354 Halogen "AU354 TT NF NAR sep TFL ohne SL bei CHO" ROM 118
AU354 XENON "AU354 TT NF NAR LED TFL + CHO SL" ROM 119
VW364 LL Halogen/XENON VW364 RdW TFL_S LL ROM 120
VW364 RL Halogen/XENON VW364 RdW TFL_S RL ROM 121
AU354 Halogen/XENON " sep TFL mit Heck,TTNF, NAR" ROM 122
AU354 Halogen/XENON " LED TFL mit Heck,TTNF, NAR" ROM 123
AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ Bulb (ged. TFL als SL)" ROM 124
AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ LED (ged. TFL als SL)" ROM 125
AU316 Halogen/XENON VW351 Südk. TFL_0 (aus 05) ROM 126
AU316 Halogen/XENON VW351 Südk. TFL_S (aus 35) ROM 127
AU316 Halogen/XENON VW364 RdW TFL_0 o. NSL ROM 128
AU316 Halogen/XENON VW364 RdW TFL_S o. NSL ROM 129
AU316 Halogen/XENON "VW364 R-SCI TFL_1 LL8TC" ROM 130 AU316 Halogen/XENON "VW364 R-SCI TFL_1 RL
8TA/8TD" ROM 131
AU316 Halogen/XENON "VW364 R-SCI TFL_1 LL Ska 8TC" ROM 132
AU316 Halogen/XENON "VW364 R-SCI TFL_1 RL Ska 8TA/8TD" ROM 133
VW351 Halogen/XENON VW351 RdW TFL_0_Ska ROM 134
VW352 Halogen/XENON VW362 RdW TFL_0_Ska ROM 135
VW364 LL Halogen/XENON VW364 RdW TFL_1 LL_Ska ROM 136
VW364 RL Halogen/XENON VW364 RdW TFL_1 RL_Ska ROM 137
VW416 Halogen/XENON VW316 RdW TFL_1_Ska ROM 138
VW465 Halogen/XENON VW465 RdW TFL_1_Ska ROM 139
VW361 Halogen/XENON VW361 RdW TFL_1 ROM 140
VW361 Halogen/XENON VW361 NAR TFL_1 ROM 141
VW465 FL Halogen/XENON VW368 RdW TFL_1 ROM 142
VW465 FL Halogen/XENON VW368 RdW TFL_1_Ska ROM 143
VW465 FL Halogen/XENON VW368 RdW TFL_1_LED ROM 144
VW465 FL Halogen/XENON VW368 RdW TFL_1_LED_Ska ROM 145
SE428 Halogen SE428 RdW TFL_1 ROM 146
SE428 XENON SE428 RdW TFL_1 XE ROM 147
VW465 Halogen/XENON VW465 TFL_S NAR /2RFL ROM 148
VN337 Halogen/XENON VN337 RdW TFL_S ROM 149
VW411 Halogen/XENON VW411 NAR TFL_1 ROM 150
VW411 Halogen VW411 NAR TFL_S ROM 151
VW411 Halogen/XENON VW411 CHN TFL_1 ROM 152
VW411 Halogen/XENON VW411 CHN TFL_S ROM 153
SE350 XENON SE350 NAR TFL_0 XE ROM 154
SE350 Halogen SE350 NAR TFL_S ROM 155
SE350 XENON SE350 RdW TFL_0 XE ROM 156
SE350 Halogen SE350 RdW TFL_S ROM 157
Hier dann noch ne kline Erklärung:
TFL_0: TFL mit NSL u. RFL
TFL_1: TFL mit TFL-Outputs
TFL_S: TFL Skandinavien m. Abblendlicht
TFL_SH: TFL mit Shutter
TFL_LED: LED-Modul mit Doppelfunktion PO und TFL
TFL_0_S: Sonderlösung Skand., Vorhalt
PO_LED: LED-Modul, nur für PO genutzt
es muss also noch was "besseres" geben für alle mit dfl.
