TTS short shifter
Just don't confuse things with the Parts Dept by telling them you're trying to fit it to a Skoda!
So what part numbers do I need for the Audi A5 "valvelift" head? (Only joking) :rofl:
  • Replies 238
  • Views 43.8k
Is 8J0711046E suitable for a CR as well Wardy? reading back through the thread I can't make out what's what. Cheers.
I bought and fitted part no 8J0711046E to my 2010 FL TSI and it seems to be the same as the part already fitted. The dimensions of the shifter were identical, the original part had VW embossed on it and the new part had an Audi stamp but apart from that I couldn't tell them apart. The gearshift action doesn't seem any different to me, at least it was a cheap mod!
It's gearbox specific. Part number 8J0 711 046 A fits the MQ250 gearbox, 8J0 711 046 B fits the MQ350 gearbox.
You'll need to check which one you've got, it's cast on the lever under the airbox.
Thought the linkage was slightly nearer to the pivot point does anyone have a pic of the two together?
Not really a mod, and hardly cheap if the original didn't need changing and the new part has done sweet FA! :wonder:
No sure on the FL - but if the Audi part looks identical to what Skoda fitted, then I think we know the answer! Need the FL part and the Audi one side-by-side, to be sure.
Fitted my TTS shortshifter a week or so ago and its a great inexpensive little mod that gives a noticeably shorter shift that feels more precise with a more upmarket feel to it. Fairly easy to fit too with hardest bit being the removal of the existing linkage. Highly recommended!
Hmmm. Someone is surely mistaken....since they have both fitted the part to 2.0 TSI VRSs!
fitted it to mine, and the same noticed the same difference as when fitted to my pre FL Octavia!
There is definitely a slight difference with the TTS shifter. At first glance the part looks identical but there is a subtle difference in the positioning of the connections which reduce the throw by 20%, or to put it another way 12.5 cm down to 10. Cracking little mod I reckon.
I agree and the difference is subtle but noticeable although I would like it shorter so may consider am aftermarket one at some time.
one thing I do find though, its a little stiffer to get through the gears when cold, or is that just me? still well worth it though!
Sounds like I shall be adding this to my todo list, EGR Delete to come 1st to replace my failing EGR Valve :thumbup:
Less leverage I imagine?
I have the Neuspeed one fitted, not a cheap mod , but 40% less travel , 2.0 TFSI :thumbup:
how much and where from?
Awesome gti, 140 pounds, was having a new diverter valve fitted, they put it on for free. Really liked Nick p `s one on his, he has the same :thumbup:
Cheers, you're right not a cheap mod!
I got my short shifter fitted today finally .!!!
Cracking mod for the money...!
A- revision part will fit in the FL 1.8 tsi 6 speed manual with an MQ250 gearbox.
Maybe this will help those looking to do this !!
  • 4 months later...
Ordered mine well before Christmas and just got around to fitting it today! guess what? it doen't sodding fit :wall: the SKU code is 8j0711046d and the arm is far too big and the travel once put back to back is exactly the same :@
£30 down the drain, time to find one that does
I've had mine on since early last year and it's great. Part number on the box was: 8J0 711 046-B
Got mine in Dec 11 code for TFSI VRS is 8JO 711 046 E
Nice one rob - Will buy this in March. Next part to change on the car :think:
Can this be had from the stealers or TPS? What sort of money are we talking?
They are less than £30 iir
