oil diution
Hi Roomies, I have 1.2tdi dpf engine, 11 plate. It appears I have had some oil dilution, oil level went well above normal levels.Garage were only going to siphon out the excess oil until I told them oil levels were normal when I first got the car, as they thought maybe level was high when I took delivery,but it was not.They then changed the oil and filter,and were sending off a sample of oil for to be analysed. I have never had the regen light come on,but I am sure it did regen ,as I got "The Smell" Only 2500 miles done so far,I do about 100 miles per week,some times more,doing 60mph on dual carriageways and other roads. Hope this not going to be recurring all the time. Anybody else had this problem :'(
A bit long winded, but this is the reason
Diesel Particulte Filters (DPF) and Rising Oil Levels - The UK Government Demonstrates the Law of Unintended Consequences
14th Jun 2010, 23:27:43
The Sociologist Robert K. Merton observed that in the field of human activity, things do not go as planned and strange paradoxes may be seen. In an attempt to be 'green', the UK government has given us a perfect case study. By mandating the use of biodiesel, it has created a huge maintenance headache for motorists and perhaps increased environmental pollution. In some cases, driver safety has been put at risk.
In order to meet the Euro IV emission regulations introduced in 2005, vehicle manufacturers began routinely fitting Diesel Particulate Filters (DPF) to their diesel engined vehicles. The DPF's purpose is to filter engine exhaust gasses in order to reduce the amount of soot particles emitted into the atmosphere.
The use of DPFs prompted some complaints. Some owners complained that upon trading in a pre-DPF model for a DPF equipped vehicle, average fuel consumption fell by several MPG. Other owners fell victim to expensive repair bills because they were not using the vehicle 'correctly', that is to say the vehicle was being used for too many short journeys causing the DPF to become clogged with soot. A small reduction in fuel economy and an occasional trip to the dealer for a small number of owners is surely a small price to pay in order to save the environment, but this is only the first phase of the problem.
DPFs can only operate properly when the engine's exhaust gas reaches a temperature of 600°C or more, since it is only at this temperature that the diesel particulate matter caught by the filter will combust. If the vehicle is driven for extended periods without the exhaust gas reaching this temperature, the filter would become clogged with soot. To overcome this limitation, vehicle manufacturers use a process called 'regeneration' to clear the excess material from the DPF. Usually, regeneration involves injecting diesel during the exhaust stroke, this diesel trickles down the exhaust pipe and increases the gas temperature in the DPF. Some of this diesel does, however, find its way past the pistons and accumulates in the sump, diluting engine oil. Thankfully, this diesel is volatile and will evaporate off over time. This arrangement worked fine until the government got involved again.
All diesel fuel purchased from a filling station forecourt has to comply with the DIN EN 590 standard. In 2009 the UK government decided to fiddle about with EN 590, specifying that from February 2010 onwards all diesel fuel would be required to contain a minimum of 7% fatty acid methyl ester (FAME), a biodiesel refined from vegetable oils. The government knew that this would cause problems with some vehicles, and that fuel retailers would be required to prominently display a notice at the point of sale warning motorists that the biodiesel tainted fuel may not be suitable for their vehicle. So the government changed the law:
"Article 3(5) of Directive 2003/30/EC requires "specific labelling" on fuel pumps dispensing petrol or diesel containing more than 5% bioethanol or biodiesel by volume. This is transposed in the UK by means of the 2004 Regulations which require retailers to label pumps dispensing such fuels with the following text:
"Not suitable for all vehicles: consult vehicle manufacturer before use."
This text reflects the fact that, until recently, most vehicle manufacturers only warranted their vehicles to run on blends of up to 5% biofuel content.
On 1st July 2009 an amendment to the British Standard for diesel (BS EN 590) was published increasing the biodiesel content of diesel allowed by the standard to 7% by volume. This was in response to revised advice from the automotive industry on the biodiesel percentage with which normal diesel vehicles are compatible. Directive 2009/30/EC amending the Fuel Quality Directive 98/70/EC also explicitly permits up to 7% biodiesel content in diesel for the same reasons. Further regulations are being prepared to amend the Motor Fuel (Composition and Content) Regulations 1999 to reflect this and other changes to fuel specifications to accord with the amendments to Directive 98/70/EC."
As surely as night follows day, problems occurred. A moment ago, I said that some diesel used in DPF regeneration can dilute the engine oil, but will evaporate away over time. Biodiesel turns out to be less volatile than petrochemical diesel, so it sets up a permanent home in the sump. Over time this causes the engine oil level to steadily rise. In some cases, the oil level has risen so high that it begins to enter the combustion chamber, causing the engine to run on its own oil and an uncommanded increase in engine RPM. In some cases, this increase in RPM has been so severe that it has caused a runaway situation. Here is an account of a Fiat 500 owner on Fiat's own web site, detailing how their engine was completely destroyed by oil contamination
"My husband was driving the car home when it started accelerating and masses of smoke began pouring out of it (filling the cabin too). He pulled into a layby and the engine was over-revving madly - didn't stop even when he pulled the key out of the ignition. It was a very scary experience."
A Volvo C30 owner relates his own tale:
"I had owned my D5 for about eight months before one day it nearly sent me into orbit by itself while accellerating[sic] on the motorway. Basically the oil level had risen so much that oil was pushed somehow into the engine and burnt like fuel. The car went flat out while at the same time billowing blue smoke from the exhaust. Scary to say the least."
Other owners are, through proper maintenance, noticing the problem before it destroys their engine, such as this unfortunate chap who is having to change the oil in his Honda Civic every other month.
...I could go on. My own Volvo V50 is busily filling its sump such that I have to visit the dealer every 4,000 miles or so to have them drain off the excess oil and diesel mixture. What is the environmental impact of all this wasted diesel, extra waste motor oil, trips to the dealer and ruined engines? I bet it's more that the meagre amount saved by adding a bit of FAME to our diesel.
Update 01/01/2011
I stopped using supermarket diesel a few months ago. Except for a few trips where it has not been readily available, I am exclusively using Shell brand diesel (the 'ordinary' stuff, not V-Power) wherever possible. This seems to have brought the situation under control, since I have now covered over 10,000 miles without the oil level rising or having an oil change.
The extra cost of about 1p per litre over supermarket fuel has been worth it, not only because I don't need to get the oil changed but because I am actually acheiving a 1-2 MPG improvement in my fuel economy.
Thats nice to know, I've long found that Shell diesel seems to like VW engines and round our way its cheaper than supermarket diesel anyhow...
(Good explanation as well, btw, thanks!!)
Sounds like scaremongering to me, my oil hasnt gone up over 2000 miles. If all that were true then all diesels will eventually just blow up and they arent just a couple of cases which could be unrelated. Theres so much crap about re DPFs at the moment.
The other big factor is whether your driving requires the DPF Regeneration cycle (i.e. the feed of diesel to burn off crud) to kick in. If you do lots of long motorway runs where the engine and exhaust system gets right up to temperature, then the regeneration process won't be needed and you'll probably never have an issue.
While waiting for a haircut yesterday, I read about someone in the UK who removes DPFs, saving up to £1500 for replacements.
What happens to owners insurance premiums after declaring the modification and the emission test results at MOT time after they have done this? Do they need to get revised V5 documents for the new specification and how does it affect warranty claims?
No idea, I read about it in the "Car" mag while waiting for a haircut and didn't have time to finish it. But it did say the DPF isn't necessary for the MOT, and most people usually have the car chipped at the same time.
