32KOFDATA ///// Fabia Sport (MKII)
22 hours ago, WillSmithy said:
Hi, Love reading through this build thread. I was just wondering, where did you get the black interior pieces from? Thanks
From a breaker's yard. They came off an VRS.
  • Replies 549
  • Views 158.2k
  • Here are the pics as I promised. Full re-trim in nappa and alcantara leather with red stiching to match the rest of the interior. The backs were painted the same colour as the car. Black Magic Pearl.
  • Short clip I did during the holidays - Belated Happy New Year guys
  • Some night shots:               and some not that fancy day shots to give you a better idea of how it looks.
Have you already swapped the interior for the black VRS one or have you not got round to it yet? I am assuming its a easy straight swap job, just wondering because I want to do it to my Fabia but if it isn't a easy swap then I might put off doing it. Thanks.
I have - it is indeed a straight swap job so suprises or issues.
On 17/02/2020 at 20:34, CrisBora said:
This project its on a league of it's own. Lovely to say the least.
What else do you plan for the car, engine wise? I think you never showed tha exhaust manifold, currently planning on make one, and because the 1.4 16v is mostly the same as the 1.6 16v that im running, or this is going turbo? 😮
Turbo is the only way. Will provide more info at a later date.
nitrous 🤔
Pics of the car as promised. Things have come a long way.
Awesome mate, loving the look of the wider arches and that spoiler! Added to
my shopping list.
just Monte Carlo from on the back? The arches look wider.
my shopping list.
The rear fenders are indeed wider. Unfortunately no easy solution here.
They were pulled and a mold was created based on the front ones which was then placed on top of them.
Fair play man thats some amount of work! Can I have first dibs if you ever start selling body panels😂
Reall y does look awesome though,Well
done.
Edited by Mickmartin
Only stuff I got for sale at the moment are the BT carbon lower door trims and BT carbon front spoiler.
I thought I was going to fit them but they didn't suit my model.
Edited by 32KOFDATA
@32KOFDATA Hello, i need your help.
Can you please update the links, or if you can tell me what i need to do this?
"Here are the items you will need.
1. 2 x springs from Steinel with part number (SZ 8010.20 x 032 32)
    This ebay shop used to have them: http://www.ebay.com/itm/181319602645?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    and they can also be found on Amazon: http://www.amazon.de/Federelement-8010-20-automatisch-Heckklappe-andere/dp/B00AC6UNQ8
2. 4 x washers
3. Heatshrink"
IDK what springs i need, because the ebay and amazon items are gone, please help, Thank you very much!
2. 4 x washers
3. Heatshrink
On 11/01/2014 at 19:42, 32KOFDATA said:
New cover was installed today and looks much better than the previous one.  :thumbup:
The whole procedure needs patience and care, most important everything is safe and works as it is supposed to.
Still very skeptical if I want to post in public the procedure though.   :think:
@32KOFDATA Thank you for the answer. One more question please...
did you switch from normal to maxidot? how? Or it's not the same fabia? I'm still searching this thread. Thank you!
So you still have the fabia then 32KOFDATA?
Yes - found a tacho with maxidot and replaced the original one.
Yes :) - and still got plans in mind.
What was the process of wiring it in?
Was is difficult?
I bought a MAXIDOT cluster with the intention of fitting it to my car but sold it on as I was told you needed a lot of VCDS coding to disable the immobiliser etc.
Thanks.
Was is difficult?
Thanks.
No wiring - plug in and then you get someone to help you code the new tacho and keys with your car.
Sweet! it is just that simple to remove like in this video?
Also, do you keep track how much you invested in your fabia? I love it btw!
Yeah it is pretty close - fitting the tacho is easy. Coding it needs expertise.
Track how much I spend? lol never, otherwise this page would never exist.
If its the same as the mk1 then its pretty easy, hard part was getting the gauges out without cracking them, I ended up putting a tiny crack in the corner of the cluster but its not really noticeable.
Edited by DieselMonte
I'm looking after those!!!! didnt had the fabia then... so... if you have them..
Unfortunately I don't have them anymore but I know someone who has the carbon door trims for sale - pm me and I will get you his info.
Bit late but when you originally changed the rear bumper when you put in the fog light into it what rear bumper was that if you don’t mind me asking ?
  • 2 years later...
On 06/04/2021 at 15:08, 32KOFDATA said:
Hello, first sorry for mi english, i want to install de springs in mi sons Skoda fabia, but when the boot is closed the struts only have 1,3 mm and the sz 8010 20x32 when It IS compresed is longer than 1,3 mm.
You have the original struts?
Edited by xplendoor
