OCTAVIA VRS MK1 PARTS / SPARES
Are the coilpacks in known working order??
If so i'll take them....can collect Saturday....only up the road in brownhills and my mate has a unit in rugeley also so i'll be over that way saturday anyhow.....
Do you have any bits of interior trim knocking about too lol
  • Replies 64
  • Views 6k
  • occyoccyoccy
    occyoccyoccy
    tomorrow afternoon if thats ok about 4ish as im out in the morning. is that ok?
Well I drove the car home from Mansfield to rugeley so presume the packs are ok. There's 3 of them I think.
The bits are in rugeley. Not sure if I'll be over there the weekend. Best to text me on 07811 110 549
What trim bits are ou needing?
Cool...
I need the surround around the stereo/climatronic panel...and the grey/black plastic strip that runs along the inside of the cill on the drivers side, the bit that the carpet tucks under and runs the length of the botton of the door.....also the centre console that goes around the handbrake and into the rear with the cup holder things in.
Stu.
Only thing I have from that list is the hand brake area part
Cool....well thats one less thing to sort.....is it in good condition, mine has had an arm rest fitted in the past and there are screw holes all over it. I'll drop you a text tomorrow in the morning then to see if you will be over there at all....
Thanks...
Stu.
Yeah in good condition but think the front cup holder is a bit dodgy but if yours is ok you can just swap them over
Brill....i'll give you a text n the morning then, i think i'll be over rugeley way anyhow.....
im in nuneaton mate so not too far from you
Hi do you still have the N/S rear caliper if so is it in good working order and how much? :happy:
Cheers!
No sorry
Do you still have the cd changer and if yes does it come with the code ?
Yes I have the changer. Where would I find the code?
have you got aerial and base? are they working?
In need of the boot interior light/bulb holder thingy if its the same as on the estates? Two of them would be even better
Dan
In need of the breather hoses as mine have split again :( do you have any of these ?if so how much
thanks
Guest
