Fabia VRS Brakes dragging
I've got a problem with the brakes on my 05 reg VRS which I'm hoping someone may be able to help me with.
F/N/S brake is dragging also affects R/O/S (but not as bad)and sometimes F/O/S but only intermittantly.
Calipers etc checked and OK.
Had a problem just after I'd bought the car (about 5 years ago) and Skoda changed the servo under warranty (thakfully) which seemed to help (but I'm not convinced cured the problem) and it now seems to be getting worse.
A quick trawl on the internet throws up one or two other people with a similar sounding problem. Problems with the servo and/or master cylinder being suggested as possible reasons.
Before I bite the bullet and start changing big money items does anyone have a definitive solution?
It's driving me mad and has the garage stumped!
Alternatively does anyone want to buy a Fabia VRS with brake 'pre-heat' facility?
Any advice gratefully received......however expensive the result!
I had this problem too, :( and yes its an expensive fix. On mine the master cylinder went and also caused the servo on the front right and rear left to go, They are arranged in a X so that if a servo fails then there is still one front and one rear brake working.
The guy at the garage was also stumped until he took it out for a long test drive took it back to the garage put it up on ramps then whacked the master cylinder with a hammer and the brakes released :think: . It cost about a grand to fix, but thats london VAG indi prices and the parts had to be shipped from Germany!
Hope thats helps. :)
Thanks for the reply much appreciated.
I thought it would be pricey to replace servo and master cyclinder (I belive they're a swine to get to) but might have to bang in a bit more overtime first before I go to see the garage man!
Has the change of master cylinder solved the problem?
NP's
yep the problem is fixed now although I fear the other servo may be on its way out :( might be worth taking it to a good local garage as a master cylinder jobbie is fairly straight forward but difficult to get too and would be cheaper than a stealer and your car wont come back with other problems.
Great.
I hope it will solve our problem to as it's taking the enjoyment out of owning the car.
Luckily we have a very good local garage. They've looked after our cars since we moved 'up north' 12 years back so I trust them not to rip me off and to do a good job.
They may not be the cheapest in town (although not dealer prices) but if you pay peanuts......
