Maxidot and sat nav help pls
Hi, I've just bought a 2008 L&K Octavia II Estate. I love it but its taking some getting used to it as its got such a lot of kit!!
The maxidot however seems to be quite minimal in terms of options when looking at some other posts on here, does it need the dealer or a software equipped garage to activate more of the options, or is it a firmware?? upgrade I need to get some of the extra features I have seen?
I'm also wondering if I need to update the columbus sat nav firmware as nothing happens apart from the sound muting when I select the phone option.
Any help greatly appreciated, thanks
Adam
Can't help with the Maxidot question - sorry.
However, the Columbus does not have bluetooth or phone connectivity as standard. That is a separate £250 gadget. Pressing the phone button will mute the volume as though you were going to make a phone call, but as their is no phone, it should revert back to playing the stereo shortly.
Oh right, shame but cheers for that.
It sounds like your Columbus has been retrofitted as my VRs has the same issue. It originally had an MFD2 sat nav but I swapped it out for a Columbus. Since then, the Maxidot has had only very basic menus (Setup, MFD and one other from memory) and I believe it needs to be programmed to the car by someone who has a hex-can cable. If you are lucky enough to live close to a member who has one, they may well do the job for you out of the goodness of their heart! I guess a dealer might do it for you but they'd charge you for the privilege. If you bought your car from a Skoda dealership, I'd get it back to them and ask them to code it in properly.
Hope that helps!
Thanks for this, but I checked my options list in the service book (see below) and I have both 9W5 and 7Q2 which suggests to me that
a ) the phone gismo should be there; and
b ) it wasn't a retrofit satnav.
Or am I missing something else?
Adam
E7L = "Highline"
1D0 = Without trailer hitch
6UB = Left exterior mirror: electrically adjustable, convex
6TC = Right exterior mirror: electrically adjustable, aspherical
1KF = Disc brakes, rear
6FB = Body-colored exterior mirror housings
1AT = Electronic stabilization program (ESP)
3FA = Without roof insert (standard roof)
1N3 = Speed-related variable steering assist (Servotronic)
1NL = Covers for alloy wheels
H6L = Tires 225/45 R17 91W
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
4R4 = Power windows with comfort operation andcircuit breaker
3NW = Rear seat bench/backrest, split folding with center armrest
3QT = 3-point seat belts with tensioner and height adjustment, front
4X3 = Side air bag front with curtain air bag
4A3 = Seat heater for front seats separately controlled
8L5 = Roof antenna and "diversity" window antenna
J0L = Battery 340 A (70 Ah)
7AH = Electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
8GU = Alternator 140 A
6Y0 = Without cruise control warning system
9AK = Climatronic with impact pressure control free of cfc
8RM = 8 speakers (passive)
7Q2 = Navigation system with color screen
8AY = Radio/navigation system
8QL = Key for locking system with remote control
8X1 = Headlight washer system
4K3 = Radio remote controlled central locking operated from inside and safe securing
B09 = Type approval Great Britain and NorthernIreland
G07 = Front shock absorption
QN1 = Drawer under left front seat
3PJ = Electric seat adjustment with memory system right, left seat mechanically height-adjustable
9P1 = Seat belt reminder, electric contact in buckle
7X2 = Park distance control, front and rear
9W5 = Car phone preparation
8WB = Front fog lights
7A2 = CD changer
3GN = Variable cargo area concept
QG1 = Service interval prolongation
0GG = Emission standard EU4
L13 = Suspension range 13 installation control only, no requirement forecast
7P8 = Electrically adjustable lumbar support for right front seat
F0A = No special purpose vehicle, standard equipment
3S2 = Black roof rails
2UA = Standard design
Edited by adamal
