Yeti wheel arch kit
Hi
Has anyone fitted the wheelarch extensions as seen on the new Urban special edition?
I got a quote from the dealer at £204.50 plus £52 for adhesive; they wanted nearly £200 to fit them!
I was interested at round about the £300 mark all in but almost £500.........!
If they are easy to DIY then I may reconsider
many thanks
Mine cost similar 18 months ago. I would let the dealer do it for 2 reasons:
1) I didn't have a garage - it's best to let it dry inside
2) Mine has fallen off 2 or 3 times over the last 18 months, I doubt Skoda would cough up another kit if it wasn't fitted by the dealer and covered under 2 years warranty for parts and accessories.
  • 9 months later...
Hi,
By how much do the extensions extend the wheel arch?
Shouldn't be a problem if you have the Urban but note that the kit cannot be fitted to a car with park assist as it obscures the side sensors.
Hi,
About 3mm!!
They are just thinnish plastic, and not extensions outwards, more a cover for the edges.
Agreed, but I think there is one here who cut a circular hole to match where the sensors was, and then fitted them.
Hi,
Just 3mm! That won't keep the car much cleaner. Sound cosmetic rather than functional. I guess I'll go for the mudflaps. I see there are wider flaps on eBay - does anyone have experience of these?
Thanks in advance
Seen a Yeti outside a Dealers workshop waiting to have damaged wheelarch extensions replaced.
Looked like it had come adrift from a side swipe. No real damage to metalwork other than broken
wheelarch extension, so would normally be a straight plastic part replacement.
But in this case the shearing of the adhesive had taken a large lump of paint off the bodywork (outside the area covered by the extension), metalwork not dented, so probably an expensive respray repair.
I suppose they can't be fitted with sticky pads to avoid the problem?
If the glued on one's fall off easily at least you can easily stick them back on if just sticky tape involved.
Edited by kibby
Hi,
Thanks in advance
Correct, they are cosmetic, but do protect the edge of the wheel arch.
Do you have a link to these "wider" mudflaps?
To seal them against the body you would need a lot of tape!! Otherwise the muck and water would get behind them.
Hi
They're not wheel arch extensions such as flared, stick on off-roady things, more side super market parking damage and panel edge gravel damage limiting bits of trim.
They only come off if they're not stuck on properly in the first place.
Hi,
Thanks in advance
Hi I have a set of 4 from ebay they are cr@p, will try and find my post on the forum to show you, may take a while
