03 vrs k04-001 project
They 100% don't fit?
Wouldn't think so mate, they only fit very select 17's might well do with spacers but couldn't guarantee, 18's min really
  • Replies 138
  • Views 17.6k
  • car is now booked in with clive for a stage 2 map also a big thanks to volvomeg for his help and info on the bam conversion.
  • managed to get a few more bits done to day! took of the inlet manifold and swapped injectors to the bam fuel rail stripped the wiring for the throttle body,inlet temp sensor, and map sensor and pull
  • Bam inlet now on!!!! I will do more but I'm going To the shop now to get a beer!!
The time it's got to beat when it goes back to pod!
Ooooo bay is looking neat mate :)
Yep I will just have to get it all shined up.
Thought I would just post up a picture of my 130 mpg daily!!
well removed the subframe tonight to replace the steering rack when i noticed the subframe bushes have had it so new ones are needed!! will also brace up the subframe whislt im there.
Yes mate got the bushes on order, braced up the frame using some lightweight alloy
Still got to finish the neatness of them! I was putting a new standard rack on but I'm now waiting delivery of a quick rack.
Kept the quick rack quiet ! For me the steering is the weak point, too many turns, not enough feel and feedback.
I thought I told you.
Well today I had a few goodies turn up!
Creation Motorsport quick shift
Creation Motorsport tip
1 ltr of super dot 4 brake fluid
And a set of front black diamond predator brake pads
Fitted the brake pads and tip flushing the fluid through can wait until its up and running same as the quick shift, also fitted the tt bushes into the subframe
Just waiting for the rack to come tomorrow then i will put the subframe back on.
Cant wait to map this bad boy ;-) pppppppooooooowwwweeeeerrrr
And mine ;)
:) goooodies
And mine ;)
and yours ;-) didnt know it was you lol
Ahhhhhhhh a fail means the car will not be done until after my holiday now! There seems to be a cir clip missing from the outer cv join which led to it popping out and as I was turning the steering wheel from side to side it knocked out all the bearings !!!!
The clue is in the name :giggle:
Managed to get a new cv joint yesterday so I fitted that this afternoon, also flushed through a load of super dot 4 brake fluid, just need to fit the quick shift stop the exhaust knock fit a new windscreen and give it a damn good clean.
Getting there matey :)
Well a little update is that I have fitted the
Quick shift
Had a new windscreen fitted
Had the exhaust sorted to the way I wanted it
Standard exhaust??
Gave the wheels a good polish and wax
And gave the whole car a good wax over
Stage 2 remap is getting closer now with only a few weeks to go, also been in talks about getting a big brake kit!!
This could also take a slight change of plan and maybe go k04-023!
Big brakes ;-) Stage 2 ;-)
Oh Yeah baby
Nice mate.
A lot of work and money needed to go k04.
What sort of output would you get from one tho?
Nice mate.
only £500 plus a custom d/p and about a day to swap it over! you would get 260-270 bhp
I've a spare k04-023.... Doubt I'll ever be using it now.
Thanks for the offer but I would be looking to buy a complete set up.
