LED license plate bulbs.
Big thanks to you.
Tomorow i will trie byte 17  change from 07 to 7.
And i dont understand what to do with byte 18.?
I am using odis from skoda dealer. My frien work there and he always give me odis.
  • Replies 52
  • Views 13k
  • Unfortunately the CANBUS LED's do not work without errors on post 2009 (white maxidot / DIS) VAG cars, the bulbs I have are CANBUS (every bulb I have used is CANBUS). Mine will not rattle or come loo
  • Sure, buy VCDS   Rosstech have spend a lot of time and money trying to find out what each byte/bit does and adding descriptions which are shown in VCDS.   VAG have no interest in a
  • Firstly, you should learn about decimal, hexadecimal (hex) and binary numbers.   The original byte 17 in hex was 70, this translates to 01110000 in binary. In binary, they are shown in
Best plan is to ask your friend with ODIS access to reprogram the lighting configuration of your BCM.
I'm not sure of exactly what the steps are, there is probably a guided function for BCM replacement that should do it.
Big thanks to you.
I did a reprograming a BCM and after what everything become ok.
After reprograming i did retrofit solution how to shown in the picture.
And now ewerything ok.
