AC drain
Hiya everyone,
Got a 2003 1.4 16V fabia. i replace the heater blower resistor as speed 1 wasn't working. Now its working, it smell (old/dry/damp) if i keep air circulation internal, not much smell.
I have look behind the front wheel arches for the AC draining pipe, just to make sure its not blocked but cannot find anything. Only thing i find is a rubber plug bottom of the body work, where AC is blowing out.
I dont really use the AC. I have remove the heater blower, all clean inside
So, is anyone know where the draining pipe is located?
The evaporator drain valve is located at the rear of the engine bay where the two hoses pass through the firewall. The valve is behind a flap of heat resistant material.
Cheers, will have a look when it stop raining
