Twin Pass Intercooler And Full Pipe Work Set Up
Selling one?? what the whole kit for the fabia?
Im sticking with this as i know it will be done properly.
  • Replies 232
  • Views 20.9k
  • NOTE If your not willing to wait, then please take your name off the list..... I'm not rushing as trying to do this properly and as cheap as possible, rather than buying aload of pipes that are not n
  • Got some pipework today I now have the full pipework set up on the EGR side, sorted some couplings for the EGR. Basically you get the kit and fit a new 90 degree Bend, slide coupling in and clamp th
No just the standard fmic
Excluding me that 15 people bang on,
1. - The Judge - BLACK silicone - ASZ - WITH EGR
2. - Alex_fabia - BLACK silicone - ASZ - EGR DELETE
3. - FR_MATT - BLACK silicone - BLT - WITH EGR
4. - L33 LHO - BLACK silicone - BLT - WITH EGR
5. - joelk2010 - BLACK silicone - ASZ - WITH EGR
6. - j.braderz - BLACK silicone - ASZ - EGR DELETE
7. - Th3 PR0ff3CY - BLACK silicone - ASZ - EGR DELETE
8. - mattievrs - BLACK silicone - ASZ WITH EGR
9. - JLneonhug - BLACK silicone - BLT - WITH EGR
10. - JARS - BlACK silicone - ASZ - WITH EGR
11. - Ant-Vrs - BLACK silicone - ASZ - EGR DELETE
12. - DanHam - BLACK Silicone - BLT - WITH EGR
13. - Justdents01 - BLACK silicone - ASZ - WITH EGR
14. - NoSmokeNoPoke - BLACK silicone - BLT - WITH EGR
15. - Chrisinit - BLACK silicone - ASZ- WITH EGR
16. - Kevin_Mc - BLACK silicone - BLT - WITH EGR
I have spoke to forge :) for the forge pipe and the x2 couplings we will need, its going to cost £77.61 EACH PERSON. What a cracking deal i think, the map pipe normally costs £41.99 ish, x 2 couplings will cost £79.78 with out delivery haha. SO WE PAY £77.61 FOR ALL 3 :) IF YOU HAVE EGR THAT IS
Good work, Cant wait to see this fitted
So tallying up - £99 for IC, £77.61 for the map sensor pipe and EGR couplings (what are couplings? are they these: http://www.ebay.co.u...#ht_3281wt_1163)? and £?? for pipework.
Edited by JLneonhug
Yup they are the ones lol, well a few prices may go up a couple of quid due to people dropping out :(. So instead of telling everyone the prices I'm going to wait, fit everything and then see what needs buying and what we can save dollar on ;)
Ok with everyone??
yup
Ok with everyone??
Maybe worthwhile copying the couplers too if the ebay seller is making money off it @ £17.99 each. :thumbup: I would help but only friend I have who is in the business makes high spec machinery, along the lines of aircraft products and components for the F1 cars. Probably not going to make 'standard' quality for our uses :rofl:.
am i able to join ?
If your 100% all the way ;) if not then no lol, but if your are and you will be willing to wait and pay then..... Stick your name down :)
17. - Wheatley - BLACK silicone - BLT - EGR DELETE
Ok with everyone??
works for me.... Judge you have a pm
Sorry, just seen your note to me - updated
16. - Kevin_Mc - BLACK silicone - BLT - EGR DELETE
update
Still awaiting final product on couplings and map sensor, will be worth the wait but it's just having to wait. :(
Have you got the lower pipework from turbo to IC sized up yet?
Roughly yeah
Hows it all going bud ?
Unfortunately still awaiting for the map sensor pipe to be made and couplings, once there done then going to order te rest of the parts and try trial fitting. There's always something that has to go on hold lol
Sorry to be abit of a downer or what ever you want to call it but those alloy pipes should really be beaded especially for the remapped guys as they might pop off :( . On another note the bottom pancake pipe is is roughly 57mm but i have replaced mine with a 51mm alloy 90 bend and a 90 degree silicone bend to the turbo using a coupler from darkside that is a 51mm bayonet. Also if you are using tbolts clamps best price and size range i found was txautosport, the ones on ebay etc dont seem to give a very good range in adjustment.
The intercooler pipes for the group buys are beaded bud, the ones in the pictures are the ones people receive. There exactly the same but with the beaded ends :) the pictured ones are for my trail fitting ;)
Cheers for heads up on t-bolts :)
Also do you have a picture of the part from darkside
Here you go
And where does that clip in bud? The pancake pipe
No directly into the turbo outlet allowing a 90 silicone bend and a 90 alloy pipe to replace the oem rubber pipe and pancake pipe.
That after i cut the pancake pipe before.
So now the bayonet connector i posted before goes into the red 90 and clips into the turbo instead of the oem black pipe and clip.
