skodalads VRS
That welding on the map sensor is amazing :cool:
Edited by pip_vrs
  • Replies 897
  • Views 99.3k
  • So, another day and more updates, the car is being painted tomorrow so these are the last prep pictures! The bay all masked up I opted to have VW rubberised spray sealer under the wings and ski
  • The car should be ready for me to be pick it up tonight! These pictures are from this morning       Spray sealer on the inside of the wings         Might have some some more interes
  • Another big weekend on the fabia!    My fuel for the weekend started with this 40oz mixed grill     Got all my boost pipes back and inlet too, now with v-bands welded too
He really is decent, check the welding of the v-band onto the inlet :D All of the work he has carried out has come to the grand total offffffffff £40 haha So cheap
So now that my car is basically finished I have just been trying to hide a few others things and tidy stuff up a bit more
I painted the covers on the backs of the lights black to help blend it in, and hidden the ballasts for the xenons behind the bumper
I needed some caps to cover the bolts on my wipers, not exactly cheap but I needed them. TPS or GSF didn't have any
Also a new rocker cover neck, to rotate the oil cap
Hopefully going to be bleeding the coolant system tonight and I have also purchased all new hangars for my exhaust so that can go on tonight too
Small update, I'm having to get the car trailered to derv tech now next Wednesday as there is no way it would pass an MOT with the emissions, remember it has nothing but a standard map so it's running awful. They believe it should break the 300 mark, we will have to see!
Exciting stuff
Edited by skodalad
What clutch/ flywheel did you go for?
that should be epic if you get close to that figure
##!!##h should look after you. Hope it makes all the right numbers on the dyno after all the hard work
Wtf has it scrambled the name D e r v t e c h for?
It did the same to me yesterday ha Thanks mate, I appreciate the kind words. I shall report back with videos and photos all being well
Made some more progress tonight even though I said it was done haha
Got my last exhaust bracket, some exhaust paste and some new glow plugs. I have never fitted an exhaust before and hope I never have that again, what a ball ache.
The state of the plugs, 3 bad, one okay. Worth changing
I also took a few photos of the coolant bleeding setup as I don't have an expansion tank, I did this for more of a reference for me but I may aswell share it
2 reservoirs, one to the top fill and one to the pipe that used to connect to the expansion tank, and a bleed. One coolant starts to flow out of the bled and into the tub, you have to remove the reservoir into the topfill and put the cap on, then do the same for the other. Tricky, and not a 1 person job
Cars going to derv-tech tomorrow! Follow me on Instagram for regular updates and hopefully some videos too! IG - skodalad
Edited by skodalad
So, A very mixed day overall yesterday.
The guy that was supposed to be towing my car was 1:45 late, which wasn't a good start to the day.
Got to derv-tech eventually, after a briet chat and a run down through the cars spec we cracked on. Reversed into the unit and it spat the bottom hose off which wasn't ideal
Then we started on the dyno and it was only running on 3 cylinders, the car has been plugged in countless times and the fault never popped up until yesterday, we managed to bodge the injector loom which i will replace as soon as its back home.
Then the join on the top boost hose that I put in to allow movement kept blowing off when it started to make boost, (complete rookie mistake as neither end has rolled lips on them) It made 255hp at 4k, with a really quick spool.
They were happy with the setup apart form the intake pipe which will restrict it, so they are just going to remove it when mapping. I'm going back on Saturday hopefully leave with a fully setup car, ill report back soon.
We are aiming for a reliable 300hp
Edited by skodalad
I am happy to report back that the car is now mapped! Its getting trailered to the MOT station today
The car made 290hp with minimal smoke which I'm happy with, I'm unsure on the on the torque figures yet.
There are a few things holding the car back aswell, I shall report back once I have been given the report
Decent power that Jack, it should feel mighty strong on the road.
I would of liked it to have broken the 300HP mark, But my criteria consisted of "I would like a good amount of power but I dont want it to be sweating its sack off" So I trust their judgement.
Ill enjoy it for the rest of the year, make minor adjustments over winter and send it for mapping again next year
Did they say why it's only made that power,or what's restricting it?
As D e r v t e c h have reckoned they got 296bhp iirc from an ibiza on a standard eng/injectors with a 2260
My turbo intake pipe, potentially my inlet manifold and my exhaust.
Looks amazing mate. Glad to see you out enjoying it
Kind words thanks mate! Falling back in love with the car again now
Good to see it's getting used, especially after all the work you've put into it.
I keep ripping my CV gaitors too. I though it was maybe because I'm running too low but now I think it could be the torque too.
I built it to drive, a lot of people take one look at my wheels and paint and think its just used for shows, but I thrash the hell out of it, and when it breaks ill just fix it haha
I think it may just be an ongoing battle for us fabia owners ha
I'm sure the torque has little to do with the inner cv boots failing as they wouldn't twist on the shaft, how could they?
It's down to the angle of the shafts as they come out of the box, simply if the car is too low the cv is working at an angle it and the boot was never designed for, and it's wearing the boot excessively quickly. You'll see the outer boots bellows making contact with each other, they don't normally, couple that with the heat they then generate rubbing together at speed and the boot gives up.
Are you fitting OE genuine VAG boots? They're a lot tougher than aftermarket stuff, that might help prolong them a bit but ultimately it's a losing battle at the very low ride heights
That is a valid point, I think its mainly down to when I air the car out, the drive shaft angle is ridiculous! Maybe its caught on something when aired out? as the tear look pretty clean.
I just got one from GSF, But When it goes next I will do both boots with genuine ones from skoda for sure
