skodalads VRS
Just now, Lofty said:
Trust me it's horrific!!
I can imagine, group chats have a tendency to be as such. Any advice with setting the stop screw and actuator as I really dont know??
  • Replies 897
  • Views 95.9k
  • So, another day and more updates, the car is being painted tomorrow so these are the last prep pictures! The bay all masked up I opted to have VW rubberised spray sealer under the wings and ski
  • The car should be ready for me to be pick it up tonight! These pictures are from this morning       Spray sealer on the inside of the wings         Might have some some more interes
  • Another big weekend on the fabia!    My fuel for the weekend started with this 40oz mixed grill     Got all my boost pipes back and inlet too, now with v-bands welded too
11 minutes ago, skodalad said:
After reading your thread, yes haha
The advice I had was, remove the circlip on the actuator lever, then loosen the stop screw lock nut, wind the stop screw out, hold the vnt lever closed then wind the stop screw till it just touches the lever. Then turn it one and a half times, against the lever. Tighten the lock nut.
Then put the actuator back on the vnt lever, use a vacuum pump to see what vacuum it takes to close the vnt lever against the stop screw. It should be about 17 on the gauge. Adjust the length of the actuator to get it spot on.
It may may still need adjusting on the car but it will be pretty damn close!
Edited by Lofty
1 minute ago, Lofty said:
The advice I had was, remove the circling on the actuator lever, then loosen the stop screw lock but, wind the stop screw out, hold the vnt lever closed then wind the stop screw till it just touches the lever. Then turn it one and a half times, against the lever. Tighten the lock nut.
Thanks for that mate, really helpful. Ill see how i get on this weekend.
Got a big weekend session, trying to get the car started, problem solving, fault finding, got to get all the breaks bled, the coolant system bled (difficult as I dont have an expansion tank) then fit all the body panels back on, get the wheels fitting properly. Loads to do
It'll make more sense when the turbos in front of you!
For the vacuum pump/gauge I used a cheap Chinese one off eBay, about £15
I'm sure it'll all come together fine, nerve racking turning the key the first time though!!!!
My mate and his dad own their own garage, they have loads of expensive equipment. So hopefully he will have something in his arsenal to test it
Tell me about it mate, Should be okay fingers crossed, been down this road a few times now haha It always ends up with my wallet taking a kicking
Updates???
11 minutes ago, Lofty said:
Updates???
Just writing it now haha
1 hour ago, skodalad said:
I can see the light!!!
Thats cause your headlights are on :dull:
haha looking good now. Would the inlet pipe not be better connected to engine rather then bulkhead so it can move with it, also be a bit stealthier.
Looking good Jack
haha nice one.
I did think about this, But with my profidiesel intake it really dosent leave much room, also there isnt another space to slot the pipe through (heater hose, catch can pipe and a few other thing are in the way)
Looking good Jack
Thanks mate :D
You really don't need to worry about heat soak into the TIP/inlet on a turbocharged car ;)
What does the turbo do to the air when it compresses it? :)
It gets heated massively,hence the intercooler after the turbo.So any mods/heat shields etc to try and cool the air from the air filter etc are a waste of time as the temp the turbo will heat the compressed air to is massive anyway.
You raise a very good point. That makes complete sense, I just spent too long cinvinceing myself it was a problem. I have a £15 roll of reflective silver tape coming so I'll use that anyway, but that does easy my mind some what! Thanks mate
Have you hooked the vacuum gauge to the actuator? A know you said it was preset but be interesting to see at what vacuum it set too. May help others compare.
looking good as always.
No not yet, My mate forgot to bring it up with him, but when I do I shall report back.
Thanks mate :D
Looks awesome mate.
does that bumper paint not just flake off seeing as its not a bumper.. or plastic and smooth bare metal haha
4 minutes ago, pip_vrs said:
Looks awesome mate.
Thanks mate!
I'm sure this would of been an issue, But I did rough up the pipes prior to painting with a red scotch pad so the paint would get a good key, the finish seams very durable in all honesty, I can imagine due to it being bumper paint is has some elastic properties
Looks excellent bud, is your fuel filter mounted on the slam panel?
Cheers buddy, the fuel filter is mounted on the inside of the chassis leg on a homemade bracket
you can see it under the alternator in the picture where the top pipe is still chrome
Edited by skodalad
Went for a start tonight and no joy, check pretty much everything until we came across the fact its getting no fuel.
So,
1) is the lift pump knackered?
2) Is it a blown fuse that control the fuel pump? if so which fuse? (I have looked at a fuse diagram and can't pinpoint which one it could be)
 any other suggestions are welcome?
Do you own an electrical test light at all?  If you do quickly stick it over every fuse, usually the easiest thing to do.
You can check your getting power to the plug for the lift pump also :)
