Skoda Octavia key
Hi
i need help with my car key, the car key was not
properly, so i change the battery, and after the change the key is not work.
then i thought i reprogram it.
but this not work
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second key.
3. Using the remote control press the Unlock button once, and the horn will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
Note:
my left dorr is not in function because not change of the electric windows wasnt work therefore it have to my change it. and the electric windows is in workshop and the dorr thing is open.
Can this be a problem that i cant reprogram the key?
Edited by singhOctavia
Possibly.
Get window fixed and try again.
Good luck.
Possibly.
Good luck.
yes i thought so too ;
thank you for answer
i got electric windows fixed, but the reprograming is not work?
can someone help?
no one will help here?
Follow this video for the Mk4 Golf, its the same for the Octavia
http://www.youtube.com/watch?v=mqZovewW2po
1. with window open and door unlocked, put the original key in the ignition and turn it to position one (warning lights on but engine off)
2. put the new key in the door and lock it
3. take the new key out then hold down the unlock button on the remote until it blips
4. unlock the door with the new key, then you're ready to go - try unlocking and locking a few times with the remote to make sure it works
If that doesn't do it then you will need to take it to a dealer, there could be a problem with the transponder in the key.
The blip bit only works on cars with factory fitted alarms
Sent from my Galaxy S2 not a Crapple!
If not then the side repeaters will just flash
Yes thank you so much for help, i took the car to dealer and yes i have problem with transponder.
and i think i have factory fitted alarms
hey there,
i have a skoda octavia 06.the alarm key fob suddenly doesnt work.normally it has a display tht shows some symbols and if the car is locked or not but now it desnt show anything.plus,when i try to open the car manually with the key, the alarm goes one { wich is normall } but i can hear a small noise on the fob wich is normal bit it desont dispaly anything.
tx
That doesn't sound at all like a skoda fob, sounds like you have an aftermarket alarm such as a clifford etc
Sent from my Galaxy S3, not a Crapple!
Interesting topic.
Have I got this right? If I buy a new key I am able to programme it using the car not a dealer. No doubt saving a few quid. Where do you get an origial key from & cut for sensible money & will it work with the immobiliser?
Alex
Nope the fob it's self will work if it's a mk4 golf type one. The immobilizer chip needs either to be a new one or your old one, a lot of places cut the blank.
I got the correct 3 button fob off a mk4 golf and fitted my blade and immobilizer chip into it and programmed it using the key method
Anyone reccomend a supplier for a new key & body. Mine has got a missing ring hoop. Do the bodies come with chips inside.
Cheers.
Alex
EBay for a new body golf 4 one's fit. Just transfer the internals, chip and key blade over being very careful with the chip which is looks like a grain of rice
Dumb question but how do you get into it? Can't see a screw head.
Alex
The screw is under the skoda badge
Many thanks Raf.
