Skoda Manuals - PDF's
None of the links work
  • Replies 52
  • Views 183.4k
  • I have put together some manuals. Here's a link I hope this is allowed? Gaurav
  • As this post contains some excellent details, pinned here for reference since the old documentation post no longer had valid links.
  • Update on link to manuals:   http://www.skoda-auto.com/en/mini-apps/owners-manuals/
  • 8 months later...
Does anyone have the service manual for Octavia 2 ?
  • 4 months later...
Hi don't know if this one has been mentioned but for vag part numbers I've always found www.oemepc.com invaluable, main page usually starts off set for VW but you can click the logos at the top of the page to select manufacturer
sorry forgot to make link "clickable"
Volkswagen
Skoda
Audi
Seat
Make sure your anti-virus/malware protection is good if you use oemepc. Last I heard it tries to install a 'bitcoin miner' in your equipment. Have I got that right @xman?
Thanks Wino, I hadn't heard about that but better safe than sorry.
This link is working as at 19 Oct 2019: https://www.skoda-auto.com/services/owners-manuals
  • 3 years later...
On 17/10/2019 at 19:20, Brugernavn said:
https://mega.nz/......
here is a link that wont die :)
Lol, dead! File no longer available.
erWin Skoda is about 7 Euro for 1 hour, put your VIN into a text file before you begin.
You can download your build code sheets also, see what it left factory with.
  • 6 months later...
Skoda Manuals - PDF's any about please
No more free copies of the manual online?!
The old iOS app I had which worked great has also been nuked remotely, I have one "MySkoda" that just wheels and crashes, one called "OneApp" that is supposed to work with multiple cars but doesn't give me a way to add a 2nd (it's set to the wife's car RN) and one I immediately uninstalled because it asked unceremoniously to create a login.
I thought I'd found a nicely old-fashioned brand in Skoda ... I'm reviewing that opinion in rapid tempo!
  • 3 months later...
hi.
I have problems with the main wire between my engine and ecu. I am looking for a diagram for an overview of these wires. My engine code is CFHC 2.0 cr 103 kw with dsg and 4x4. I have found some diagrams with these that do not show the correct color codes on the wires. I am trying to find which wire and pin on the ECU belongs to the Intake air temperature sensor, as it seems that I have a break in this wire. A diagnosis shows that there is a break. because I read a value from the sensor showing minus 40 degrees on the air entering the engine.
@AreBerg Yellow wire at pin 2 of connector for G42 goes to engine ECU pin 30 on 94-way connector. Brown wire from pin 1 of same connector goes to ECU pin 66 of 94-way.
On 22/03/2024 at 14:55, Okedokey said:
Hi, sorry I never got a chance to say how much I appreciate the infos.
Shortly after my post, the car developed multiple issues and I got some health issues at the same time. End result being the car's been sitting on my drive since then, unused apart from the occasional start and slow move around in my drive and I've been unable to work on it.
Truly good of you, thanks!
  • 3 months later...
Not a single link works
