Ok... it seems ive broken it ...... Quick rack time ?
Ok it seems ive broken it :(
So whats a quick rack
How much
And what do i need to get one one ?
Are they direct swaps ?
Edited by Lloyd55vrs
  • Replies 123
  • Views 5.6k
  • I like it .... needs new rack, ends up with new front end setup !!! This place is dangerous lol
  • some later 180 did have a quick rack believe it or not, but agree go for 225 to be sure.....As will only make Lloyd panic with too much choice.....lol. Bet he is having a sweat already....."shall i f
  • i know, a year ago i logged on to try and figure out a fault code, now i have a car that cant drive through a town near me cos of an aggressive speed bump
think its the audi s3 you need one from, then you need some sort of trackrods from them aswell
Audi s3 and leon cupra R's use them and poss TT aswell but not sure on that,
Like said above our track rod ends dont fit
Best to go the whole hog with TT hubs and arms... and yes, the TT does.
Also they have a higher rated steering pump, which compensates for the gearing. Steering is a little heavier without it, as you would expect. Not a bad thing though...
So its not just a rack swap then ?
I could get my rack reconditioned ? Is that ok or iffy ?
Got a rack here Lloyd off mine, but god know how I'd ship it lol
yes the tt ones are quickracks, only the 225bhp models tho, don't get caught out buying a 180bhp spec one.they are a direct fit.You can get a recon rack, or yours refurbed, not worth it for the cost tho, as its gotta come out, might as well put the tt quickrack back.as demonufo says, time to fit the other associated bits like hubs, front arb, and wishbones with uprated bushes as you gotta drop the rack anyway. Also you should renew balljoints and tie rod ends, and might as well do droplinks.Sell those bits you have and you will have some spare $$$
U could be a star ;)
Pm'd
I'll look into the quick rack but i think price shall be unfriendly
Say woooot :)
So whats my shopping list lol
1 225 tt rack
2 tt ball joints or octy ball joints ?
3
4
5
6
Pm'd
i think trev has a quickrack?the rack secondhand should be anything between 75 if you are lucky, and 125 ish, you can find them on the bay, on ed38, golfgti forum amongst others, just trawl the for sale ads
Yep these racks all fit, TT 225, some later TT180's, TT Roadstar, S3, R32 and LCR have the quick rack.
On a buget you can reverse the VRS track rod end (upside down) and get away with using Audi or Seat ones.
Although I went the whole hog with mine , Hubs, Wisbones, Rack, FARB etc
Although I wend the whole hog with mine , Hubs, Wisbones, Rack, FARB etc
thought all the 180s were normal rack?either way if you def get a 225 rack, then you know it will be good.as bowders said, i ran for a while the vrs hub setup, with tt stuff with no issue at all, if you are looking to save money, this is a good compromise (the hubs are the expensive bit as unless as they need the 2wd flanges/bearings in them)
some later 180 did have a quick rack believe it or not, but agree go for 225 to be sure.....As will only make Lloyd panic with too much choice.....lol. Bet he is having a sweat already....."shall i fit it myself or get someone else thread coming up"........hehe :rofl:
Sweat mate..... Full on freak out :(
I dont even know what a steering rack looks like "sssssh stop it"
So witgout huds wishbones etc ( the whole hog ) are they still fine sturdy and safe ( not classed as bodge is it ? )
The whole hog sounds expensive :(
Just swsp the rack
The tie rods off your std rack will fit fine. Swap them like for like so what omes off one sid goes back on same side. Only need to swap sides over if you use the hubs off thoes cars!.
The only difference with the proper quick rack tie rods is they are thicker so dont go getting the tie rod ends from one of thoes cars unless you get the rods too.
Youll not need them tho just get new std vrs ones and use your tie rods.
Again make sure you put them on the right side.
Its a straight swap. Ide get the farb too seen as subframe comes off. Swap them bothe out and thats it youll not need to drop it again then. Leace the hubs n that as its expensive and not hard to do later.
Dont need anything else mate if the rack needs changing just change it.
List:
R32, tt 225, lcr, s3 rack
New boots posibly
New clips
New std tie rod ends(not essential as you could remover the tie rods from the rack and leave attached to hub if really strapped for cash.
New subframe bolts.
Ill get pn up for you lloys after work in the morning.
Cheers mate
But watch it billy :D you are my closed fix-it yourself briskie lol
Lloyd on the 29th december im traveling the length of the country, from blair across to glasgow then down past carlisle and m6/m5 all the way.
The rack trevorb33 has im sure we could figure a meet point on way down
If you can manage until then i could do a skoda courier for you and bring it to a services in bristol? I know its a bit away but i know you dont drive it much. For free of course
Just a thought
Edit: might be a bit out of the way for trevor actually as he is 40 miles east of the motorway im on.
Edited by Lofty79
Cheers guys :)
Nice to feel im doing something rite to get so many top briskies offering help
Ive came out my corner and stopped crying now lol :D
I just wish i knew 100% it was the rack :(
is there more than one type????? i thought mk1 octy racks mk4 golfs, boras, s3s, a3s etc etc would fit. just gearing speeds differ
It sucks :( just as was getting n habit of using him
I just swapped the rack for an S3 one and swapped my tie rod ends onto it. Had to borrow a big spanner for the 32mm nuts.
aye getting the spanner is a problem but mine werent on that tight at all, which was nice
:( dunno what to do
Id sooner avoid like a mickey mouse aftermarket one
well if your searching for one, and can wait till i come down, you can search a wider area, and ill bring it.
i know of a vrs breaking near me, want me to price it, ill get it cheap if i remove it
Are you sure its rack? What are the symptoms???
Edited by Lofty79
Like a clunky knocky noise when u wiggle the wheels
But not when its cold ( first started or been sat )
And not if wheels are in the air
Comes on louder after a umm. A bit of spirit
Comes on lots when been a dickweed :(
Guys said when was jacked up on 4 poster it would stop if grabbed the rack or sumin
