wiring problem
I have fitted a sub in my fabia vrs all the wiring is correct and sub works fine. the problem i have is when i turn off the engine and remove the key my sub is still getting a direct power source. can anyone suggest anything, i have thought of just sticking a switch in the power cable.
Stick a relay in line, and find a ign feed and trigger the relay so when the engine is running the power goes to
the amp, but when you switch off the power is killed to the amp
Radiotwo
my sub has a built in amp does this change anything
Sounds like you have it wired wrong,
There should in addition to the supply from the battery, be another connection from the headunit which is usually labeled as remote, amp remote or simillar. The remote cable operates a relay built in to the sub and it will cut the power when the headunit is switched off.
+1
Pin-6 (yellow section) of the T20 connector is the output for an external amp. This usually goes to an input on the amp/sub or a relay in cases where there isn't such an input. Don't use an ignition feed or you will find that you can turn the radio on but the amp/sub will have no power.
Hello and welcome Luke :thumbup:
Sorry for the confusion, I put "Amp" and should have put Sub
Sorry
Radiotwo
thanks for the help guys will have to give these things a try
