Activating cornering fogs & coming home lights?
thats fair deear lad!! nobod down my neck of the woods with it either!! i suppose the main dealers could sdo it maybe??
  • 6 months later...
  • Replies 79
  • Views 23.9k
  • there is no "cornering fogs" on maxidot, even if enabled. its purely a vcds thing. CH/LH on maxidot = yes. i've got my CH/LH using the fogs, not the low beams (by default). on a my11 vrs.......
  • 2) Some dealers struggle to activate them using their diagnostics system, I don't think theirs is as comprehensive as VCDS. Good luck!
As Silver says above, I activated his cornering fogs for him, and yes it is a VCDS job. It does not even show up as an option in maxidot to switch on and off when it is activated in VCDS. It's around the 07 plate age where activation is possible.
On a personal note, I activated the cornering fogs I my 08 plate Elegance, but have since switched them off as I didn't see any benefit from them.
Coming home/leaving home lights can be activated on any age of Octy 2, and if you have maxidot it can be switched on and the timings altered from there. If you don't have maxidot, the settings can be made through VCDS.
Mike
Which gateway is it under please to do this?
to activate cornering fogs lights via VCDS:-
This is great, why are bytes 3 and 4 ticked please. I do not know what they mean? Also in byte 12 where the coming home is ticked for manual and automatic. Is manual for people like me with no light sensor. So I guess it works from having the headlamps on or off?
Sorry if I am being dumb.
Cornering Foglights
Control Module  > [09] Central elec / Coding / Long coding helper / byte 14 / bit 5, Check the box.
Exit
Do it
Coming Home Lights via foglights
Control Module  > [09] Central elec / Coding / Long coding helper / byte 17/ bit 3, tick the box.
Exit
Do it
I have the cornering fog lamps on but I
Didn't think CH/LH worked with the FLs without a light sensor??
Pretty sure I've tried to activate it for people before. Think the coding accepts but they refuse to work. Must be to do with controller updates, that it needs to receive information from the light sensor, on whether to turn CH/LH on or not
This is where I am stuck it all says should work but I have no light sensor I have 2010 vrs with Maxidot. There is an option to have the CH LH as manual though in the vcds. I wonder whether this would do it. I have read on Yeti I think that they have lights on and it works?
