thoughts on this?
It is a split r valve, and i have just orderd it, will put up pic's / vid once i fit it.
Y do thay need to "set up" and how do you do it??
Marko
no worries
something like this is a good cheap alternative. You can then replace the Cone filter maybe later for a better version like a K&N
http://www.ebay.co.u...=item5199df91b3
and the Golf one is the same fit as the octavia one ?
So you wouldn't recommend fitting the mushroom on the end of the one you linked either ?
Marko
Ah ok thought you just ordered the std 007p version(sorry Lloyd you were paying attention)
I think they come pre set but come with instructions anyway.
Yes Golf one is the same. So is the Seat Leon Cupra and Audi A3 as they all use the same engine and air system and the filters all bolt up the same.
Just don't go for a Audi S3, or LCR as they have 3" MAF so the hose will be bigger although these are not common on the web anyway.
Those mushroom are not very good a filtration and keeping dirt out, plus they do not have a very large area which is what you should be looking for.
They should be kept for Scooby's :giggle: Although would never put one on mine when i had a scooby.
this is what you should be looking for or similar. Nice size and filtration and sits correctly.
yours looks perfect, I'm guessing the one you linked to above wont sit as good as yours ?
Cheers the one I linked or any similar style to that should be the same as mine. A lot of folks on this site use the same as that link and do ok.
I did pay a lot more for mine though.
Sent from my GT-I9300 using Tapatalk 2
thx, I found a carbonio in the for sale thread, I worked out by the time I added a K&N filter to the cheaper Ebay one, it would work out a similar price, so might aswell go with the better one to start with.. so the HKS mushroom will be off soon hopefully
Nice one yep the carbonio is a good make.
