Adam's Fabia vRS Mk1 - 2.0 litre GTB powered
Had already bought the paint before your comment Alex haha. I enjoy cleaning so will give me a challenge ;-)
Nothing done on the engine today whilst I'm awaiting parts, got the remainder of my parts ordered that I require for the rebuild so I set about cleaning the engine bay up ready to accept the new lump once complete.
This is how the engine bay started off
And the finished product
  • Replies 303
  • Views 43.4k
  • Managed to get the ARP lube on all the bottom end and get it all torqued up this morning. Whilst I was torquing the bottom end down I had threw some parts in the wash off tank at work, mainly the s
  • More work carried out for the engine build over the last couple of days. The pistons have been fit to the conrods, not before weighing them all to make sure they are equal in weight. The block
  • Thanks very much Jars, tbh it was fairly simple to make, just faffing about to cut the material to the correct size and angles. Further progress update. I made a start on polishing the wheels up, I
Whilst it's so easy to access vacuum out your PAS fluid and fill with fresh ;)
It's not meant to be changed in any service schedule tbh,but neither is gearbox oil :)
Funny you should mention that I noticed it was on min and looked a bit horrible. Does it take a certain spec fluid or does any old power steering fluid do?
Yeah it's special stuff,motor factors will sell it,Febi make some which I used.
1 ltr is plenty :)
Excellent build, top work!
Update time. Work has been fairly slow as I have been making sure everything is 100% spot on.
Cracked on getting the block honed up to the finished size.
Then skimmed the top flat. Only removed 5thou to get it to clean up
For the statement regarding the cylinder walls looking thin, still plenty of meat left in them.
Left the block overnight to go in and steam clean it off and get it painted.
Came into work this to find this....
Set about masking the block up ready for paint.
After painting the block I came back a few hours later to be greeted with this....
And the finished article after removing the masking tape.
Going to make a start on rebuilding the engine tomorrow, get the pistons fitted to the rods and have them dropped in along with the crankshaft.
Edited by Southy
Now that's bright lol! Not too my taste but it's unique..
Love seeing this depth of skill :-)
How long do you estimate it will take until it's back up and running?
Thanks very much, I want to get it to match my colour scheme. Once everything is refitted to the block, very little of it will actually be seen.
I'm hoping to star dropping the engine back in next weekend. So probs another 3 weeks yet till she is back on the road and running once again
Looks awesome mate. I know where to come if I want my engine painted ;)
Looks mental mate.. lovin' it.
The missus wants an engine to rebuild, it's either a 1.8T out of a vRS (when we finally get one) or a Vx Z22SE..
Real top notch skills! :-)
You're a wizard!
Sent from my SM-N910F using Tapatalk
Thanks very much guys. Hoping to start making some major progress this week now I have all my replacement parts.
Looking well now everything is so clean [emoji108]
This really is something else. Keep up the great work mate
Thanks very much Charlie, its getting there. Not had much time to do a great deal lately in it due to work. Ordering my injectors come Monday, I've ruled out a cam for now due to the costs involved. Would of been nice whilst it was in bits but it's another £600 I can't stretch the budget to.
Got the coolant pipe painted up.
Fitted the coolant pipe along with a few cable holders and brackets and the replacement cam cover plastic.
Then set about pulling the injectors outta the head. Will be giving the head a final clean off come Monday and then a re-oil up before setting about refitting it.
Most likely won't be able to fully torque the head down due to how tight the headbolts will need to be so will leave the final 90° turn till its bolted back in the engine bay.
Edited by Southy
Thread porn B)
Massive fan of the work going into this car, and the thread makes such interesting reading compaired to others just bolting parts on (mine included :D )
Would love to see this in the flesh when all is said and done. :)
I snapped the plastic backing too. Reason being that you must remove the cam pulley first.
So you'll struggle to get the new one on with the pulley still on!
Sent from my D5503 using Tapatalk
Thread porn B)
Thanks very much pal, I do enjoy a good project thread to read instead of just clean car pics (guilty of those myself at times), makes it much more interesting. I will more than likely be out and about with the car this year at several shows so you will most likely see it, be a shame not to show it off a little after all this work carried out :D
You can just about get it to go behind it but its a little tricky and needs to be in the correct position. I will however be fitting the head back on without the pulley to make life easier.
Great work, what injectors have you gone for? There is a NPS cam for sale in the classified for 300 from a very famous seller! Might be worth a punt?
Great work on this Adam it is truly a work of art. Shame to get it dirty lol. :)
