Adam's Fabia vRS Mk1 - 2.0 litre GTB powered
Great work, what injectors have you gone for? There is a NPS cam for sale in the classified for 300 from a very famous seller! Might be worth a punt?
I'm going for DSSR 130% that way I have room overhead for future power upgrades.
I had thought about buying the cam from Steve but I dunno if I would trust him....
  • Replies 303
  • Views 43.4k
  • Managed to get the ARP lube on all the bottom end and get it all torqued up this morning. Whilst I was torquing the bottom end down I had threw some parts in the wash off tank at work, mainly the s
  • More work carried out for the engine build over the last couple of days. The pistons have been fit to the conrods, not before weighing them all to make sure they are equal in weight. The block
  • Thanks very much Jars, tbh it was fairly simple to make, just faffing about to cut the material to the correct size and angles. Further progress update. I made a start on polishing the wheels up, I
Nice :)
The little bit of green you can see now of block looks spot on!
Cheers Kev, doesn't look too OTT at all now it is all back together. Can't wait to get the car up and running once again and back driving it. I have missed it so much.
How much power does the 2L make with a 2260 at 2.5 bar?
Not sure just yet as it isn't up and running and mapped just yet. I think it will be around 280-290bhp myself however
Great work and great enthusiasm for the build! Look forwar to your review of the 2ltr good luck with the mapping etc
Fantastic news! Flywheel sounds very quiet.
Can't wait to see the results!
Sent from my D5503 using Tapatalk
I bet you had some hand In mouth moments seeing possible blue smoke! Can't wait to see how much power this engine will make!
I was dreading it and fearing the worst and maybe have to pull the engine once again and re-ring it and glaze bust the bores so was majorly relieved to see it clear up once John had altered the fueling.
Been trying to sort out some logs but my VCDS lite refuses to connect and can't communicate with my ECM so I'm at a loss.
How you finding ur mpg with injectors in ,I've just fitted my 130% last weekend but only running a base file until I fit some stronger headbolts
Can't say I have noticed a major difference really. I put about £30 worth of BP ultimatr in it the other week and it's done about 250/300miles on it but I'm not pushing it that hard just yet due to running the engine in still. I am also running a base map of 1.3bar. Hopefully be upping that soon now more and more miles rack up.
Edited by Southy
Mine when it was on the first couple of maps and really smokey was doing 300 miles to £50 using it daily.
Now seeing around 400 miles to £50 on the much cleaner map :)
Major update time. Been a very busy boy lately, car has now done around 1500miles so it has had an oil change, I had issues with my VCDS cable so wasn't able to carry out any logs until John kindly sent me his spare, however I can't run any logs as the car if currently off the road once again.
I have stripped the front and rear suspension off to send the tired looking coilover springs to the powdercoaters to tidy them up for the show season. I have also stripped off the wishbones and rear beam and the RARB also also sent them to be powdercoated also
I then had to remove the bushes from the rear beam using a drill, hammer and chisel anda blow torch
The replacement bushes for the rear beam along with some shifter link bushes
The nice pile of parts to be taken to the powdercoaters
Some of you may notice the part on the left in the above pic. I decided to make myself a custom crash bar from 1" box section.
First of all take one majorly butchered standard crash bar.
Then bolt it onto a piece of dexium to act as a jig.
Then take an angle grinder to the front cross member and remove it from the legs.
Then cut the legs down to the desired height
The work then started on the framework.
A sample fit to see what it looks like
I then decided to add cross members for extra support
And all welded up
This weekend I set about cleaning the coilovers and the neglected wheels.
Edited by Southy
very nice crash bar, how long did it take to make?
Fancy taking measurements ;)
Took me about a day and half to make it in the end took a bit of time and effort to measure and get it all right.
Its 1m wide and 10cm high. Its 1inch box section with 2.5mm thick wall. The cross sections were started an inch in from the ends and equally split between the 4 parts
Epic built! Are you a vehicle technician?
Thank you very much. I'm not no, I am a CNC machine operator by trade but have been messing about with cars and trucks from a young age so I'm pretty handy with a spanner
Still my favourite build thread  :clap:
Very interesting work with the replacement Crash-bar. You've made it look and sound so simple, which is obviously credit to you, sir  :envy:
Top work, looks excellent
