Front fog light bulb removal - mk2 vrs
Does the foglight unit come out or do you remove the lower plastic grille & access the unit through there?
Ive had a search and not sure the previous posts relate to the round fog light unit.
Can anyone also advise the correct bulb for the foglight, the manual says it is an H8 bulb but have discovered through the vwaudi forum (google result!!) that this isn't the case.
Cheers.
you got a link to proof that its not H8?
The manual wont have the wrong bulb type in there, wierd if it does.
EDIT: found a thread on here where people say its H1 or H11 aswell.
Edited by ryan-re
Stroll on! I guess the only way to find out for certain is to remove my existing bulb then.
For a cooking Octavia, don't know how different the vrs is. Other than round.
I think you can get your hand round and pull the connector off, or a screw or two to take the whole unit out, which I think I had to because the connector was too tight for me to move at that angle. Mine is a HB4, according to my records.
Just googled, and from the looks, H8 and HB4 look the same physically, maybe different wattage though.
There seems to be lots of multi standard, multi naming of things like bulbs. PITA.
well, the link posted says the H8 is wrong.
So the list grows:
H8
HB4
H1
H11
Its a H1 for vrs RTFM :p
Manual says H8 so RTFM lol
Look closer h8/H1*a
*a VRS
not in my manual
Wierd eh?
extremely weird, even more weird is my book pages go up to 287 lmao.
bar yours being petrol and mine a derv. what year is it? Mines a 2006
maybe they changed the manual
Edited by ryan-re
2008 58 plate registered 19th dec 2008
they must have changed it at some point i guess. Question is, did they change the bulb in those 2 years
i have a copyright symbol and 2007 in the book.
Not H8 anyway for a 2012 reg vRS as I got some and they do not fit.
I have now ordered some HB4 so fingers crossed.
Was yours blown? I don't see the point of upgrading them unless broken.
No.
I am putting yellow bulbs in them.
So how exactly do You take the unit, as i have to replace the glass on one of mine
Stick your finger in the hole in the grill surround and pull it off. 3 torx screws to remove the lamp.
3 minute job
I don't think the glass alone is replaceable, I'm sure you need a whole new unit...
im not sure about pre-FL, but the glass comes off the front of my FL vRS model. its clipped together with a rubber gasket in between. come to think of it, the fabia vRS LED fog lights/DRLs are the same and come apart in the same way.
GUYS have we found out what bulb we need for the MK2 VRS, pre FL and FL please
