Glow Plugs?
The engine management light came on other day, after checking with VCDS I have the 17056 error code (Cylinder 2 glow plug).
It seems like an easy enough job to do & Eurocarparts list the NGK glowplug at about £15 - has anyone used NGK glowplugs before (or any other brand) and have any good or bad things to say about them?
Cheers!
I like your picture! :)
I've used NGK spark plugs, but that's of no use!
These people, ECPs sister firm, are cheaper too. (I managed to order a BOSCH Maf and fuel filter for less than the cost of the same MAF from ECP.)
http://www.carparts4...o.uk/glow-plugs
Edited by TriggerFish
Cheers!
I have replaced my factory fit bosch glow plugs with NGK ones after one failed. Replace the set as after I replaced one, two others failed within the year. Seems to run ok on NGK. You need a longer socket and a torque wrench to complete the task.
28 quid a set here.
http://www.ebay.co.uk/itm/4x-NGK-NTK-Diesel-D-Heater-Glow-Plugs-SKODA-FABIA-1-1-9-V-RS-VRS-03-08-5065-/160858016033?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2573e28921
Id tried TPS. See what they cost for the genuine ones!
The "genuine" bosch ones on mine lasted just over 3 years before they started to fail. My car seems to start better on the NGK ones. I think TPS were a lot dearer than 28 quid a set when I rang them.
Cheers chaps! I'll treat myself to that set of 4 NGK plugs from eBay.
Well my ones from the factory have last 7 years...
Excellent, I will let you know in a few months if my NGK plugs lasted longer than the OEM bosch ones.
Edited by djdazzy
You said they lasted 3 years, so letting me know in a few months is no good to see if they last longer...
Thinking before you type would be a great idea
I was attempting humour :) How do you know you have still have the original plugs in your car? You only bought it last year....
Full service history with a documented list of parts replaced from when, where and mileage, down to nuts and bolts! One of the reasons i bought the car, 10bonus points for research.
Thank you. Down to nuts and bolts eh? :) Enough said !
