VCDS read out for Superb I. need help.
i have a problem of my car using rather alot of diesel at the moment. the car is bringing up figures of around 20.5mpg for an average trip while im working and the best i have got it upto was 38mpg on a 50 mile round trip along the local A-Roads.
i got the VCDS read-out earlier today but i dont know if anything on it could be responsible for the fuel issue.
i have also been told it could be a turbo actuator that is at fault but im unsure if thats something the VCDS would pick up on.
Here is the read-out i got from VCDS:
VCDS Version: Release 11.11.5
Data version: 20121222
Saturday,26,January,2013,13:21:37:03734
Chassis Type: 3U - Skoda Superb I
Scan: 01 02 03 08 15 16 17 19 36 37 46 47 55 56 76
VIN: TMBDS63U159080649 Mileage: 455050km/282754miles
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 KC
Component: 1,9l R4 EDC 0000SG 4896
Coding: 00002
Shop #: WSC 00028
VCID: 62C1905EEE412708578
TMBDS63U159080649 SKZ7Z0D2574828
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 00028
VCID: D3AFC59A21FB5E804CE
Address 08: Auto HVAC Labels: 3U0-907-044.lbl
Part No: 3U0 907 044 A
Component: CLIMATRONIC S B5 C 2004
Coding: 17000
Shop #: WSC 00028
VCID: 31632F12FB27CC909E2
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 0C AIRBAG VW61 0K 0003
Coding: 12355
Shop #: WSC 00028
VCID: 2757C14AC5E38220406
4 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
32-00 - Resistance too High
01218 - Side Airbag Igniter; Passenger Side (N200)
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 3U0-920-xxx-17.lbl
Part No: 3U0 920 911 A
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 31425
Shop #: WSC 00000
VCID: 2F67296AED13DA60886
1 Fault Found:
00476 - Control Module for Fuel Pump (J538)
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 25014
VCID: F0E56A16B0AD059851C
2 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: BE Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 04940
VCID: 36691C0E1249EBA8CB0
Subsystem 1 - Part No: 1C2959802
Component: BE Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C2959801
Component: BE Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 3U0959811
Component: BE Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 3U0959812
Component: BE Tõrsteuer.HR KLO 0202
3 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
00933 - Electric Window Motor; Passenger Side (V148)
35-00 - -
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-00 - Implausible Signal
End ---------------------------------------------------------------------
