Doubt Door Open Set up
Hi,
When you make the set-up in the comfort menu, there is the possibility to choose which door will be opened when you click the remote key
Here are the options I find
So, I understand the following
  • All doors: All doors will be opened with the first click
  • Single Door: Only Driver door will be opened with the first click
  • Veh. Side: The two doors from the driver's side will be opened with the first click
  • Individual: Here is my doubt. What does this option make different from the rest?
What does the manual say?
The manual does not even include all the options I've just put.
How is this menu option in your cars?
Try it and find out? What's the worst that can happen? ;)
If you select it, will it not then show a list of the doors so you can choose one?
Do you have Kessy? That may change the options when you unlock using keyless as well.
