Cruise Control Challenge
Hello!
Recently a tooth broke off the diff and binned the gearbox :sweat:
Took it to my local independent (DS Motors) who are really good, used them for years and had no issues.
They fitted a replacement gearbox and diff.
Great you say... but now my cruise control does not work on top gear (5th). Works in all other gears fine.
There are no fault codes showing.
The only difference is that the gear ratios are subtly different...
Top is much longer giving around 95mph at 3000rpm!
4th is about the same as the original 5th gear was and the other three ratios are the same.
My findings are based on what I believe the original ratios were as:
Gear Ratio
1st 3.300
2nd 1.944
3rd 1.308
4th 1.034
5th 0.838
Final Drive 3.647
Anyone got any ideas what the issue could be?
what box has been fitted then
not an 02j eha by the sound of it
  • 2 months later...
No idea, what box was fitted, I will see what I can find out....
Sounds like a 5 speed diesel box off a 100 or something if 3k is 95 mph.
Sounds loke a sensor not right somewhere might be thinking its in neutral so wont activate.
