SOLD - Specialized Camber Elite
NOW SOLD
all photos here: https://plus.google....=CNHe4LrX1ofFYA
TECHNICAL SPECIFICATIONS
FRAME: M4 hydroformed tubing, sealed cartridge bearing pivots, disc only, Command Post routing, replaceable deraileur hanger, bolt on cable guides, 120mm travel
REAR SHOCK: RockShox Ario RL, air spring, rebound adj. and LO, 7.875x2.0"
FORK: RockShox Recon Gold TK, Turn Key damper, Solo Air, alloy steerer, rebound adj. w/ LO, disc only, 120mm travel
HEADSET: 1 1/8" upper and lower campy style cartridge bearings for integrated alloy HT
STEM: Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
HANDLEBARS: Specialized XC low-rise, 6061 butted alloy, 680mm wide, 8 degree back sweep, 6 degree up, 31.8mm
GRIPS: Specialized lock-on, S/M: Grappler, Other: Rocca
FRONT BRAKE: Custom Avid Elixir 3 R SL, hydraulic disc, tool-less reach adjust, alloy backed semi-metalic pads, G3 Clean Sweep rotor, S/M: 185mm, L/XL: 203mm
REAR BRAKE: Custom Avid Elixir 3 R SL, hydraulic disc, tool-less reach adjust, alloy backed semi-metalic pads, G3 Clean Sweep rotor, S/M: 160mm, L/XL: 185mm
BRAKE LEVERS: Custom Avid Elixir 3 SL hydraulic, tool-less reach adj.
FRONT DERAILLEUR: Shimano FD-M660 SLX, E-type for DMD, top swing, bottom pull
REAR DERAILLEUR: Shimano RD-M772 Deore XT Shadow, long cage
SHIFT LEVERS: Shimano SL-M430 Alivio, 9-speed, trigger
CASSETTE: Shimano HG30, 9-speed, 11-34t
CHAIN: KMC X9, 9-speed, w/ reuseable Missing Link
CRANKSET: Shimano FC-M521, Hollowtech, Octalink spline, replacable rings, S: 170mm, others: 175mm
CHAINRINGS: 44A x 32S x 22S
BOTTOM BRACKET: Shimano BB-ES25, Octalink spline, cartridge bearing
PEDALS: Resin Test Ride Pedals with toe clips, CEN std.
RIMS: Custom DT Swiss 445D, alloy disc, double wall, pin joint, eyelets, 24mm, 28/32h
FRONT HUB: Specialized Hi Lo disc, 32h, QR
REAR HUB: Specialized Hi Lo disc, double sealed cartridge bearing, QR, 32h
SPOKES: 1.8mm (15g) stainless
FRONT TYRE: Specialized "The Captain" Sport, 60 TPI, wire bead, 26x2.0"
REAR TYRE: Specialized "The Captain" Sport, 60 TPI, wire bead, 26x2.0"
INNER TUBES: Ultralight presta valve
SADDLE: Specialized BG Rival, 143mm width
SEATPOST: 6061 alloy, 2-bolt micro adjust, setback head, 30.9mm, S/M:350mm, others:400mm
SEAT BINDER: 34.9mm clamp ID, 7050 hard annodized alloy collar w/ QR, black
NOTES: Protective clear coat, derailleur hanger, reflectors, owners manual
SOLD
Guest
