Posted
Hello everyone, I am wondering if it is possible to install front springs from 1.6 on my felicia 1.3, will there be a noticeable difference in the suspension in addition to stiffness?
The springs for 1.3 are not enough for you?
There are stock and aftermarket, factory specs or 30-40mm lowering that can cover your needs.
I just don't want to underestimate it, even on the contrary if it's possible, I need rigidity, and I'm also wondering which manufacturer is better to choose
No normal-light sport driver can beat Eibach springs 40mm lowering.
Apex 30mm lowering are extremely good, you can find also H&R
Why the stock of 1.6 can be considered better than these?
Kayaba, Spax, Sachs, MAD, Monroe, SKF, Ridex are OK for normal use.
The Skoda parts catalogue lists six different front springs and six different rear springs for the Felicia.
However, as you have a Felicia 1.3 I suggest you go for 6U0411105D front springs and 6U6511115A rear springs for the hatchback version or 005055544 rear springs for the estate version.
Felicia front springs
2 6U0411105D Coil spring
for vehicles with reinforced
bodywork
for models with anti-lock
brake system -abs-
0-575KG   FELICIA 1,3
COMBI 1,3
2 6U0411105E Coil spring
bodywork
brake system -abs-
576-605KG   FELICIA 1,6
COMBI 1,6
bodywork
11.95
COMBI 1,6
2 6U0411105F Coil spring
11.95 -
605-635KG   FELICIA 1,9
COMBI 1,9
2 6U0411105G Coil spring
11.95 -
636-665KG   FELICIA 1,9
COMBI 1,9
2 6U7411105B Coil spring
for models with
heavy duty suspension
575--605KG   FELICIA 1,3
COMBI 1,3
2 6U0411105H Coil spring
for models with
    FELICIA 1,6
FELICIA 1,9
COMBI 1,6
COMBI 1,9
https://www.lllparts.co.uk/catalogs/skoda/CZ/FEL/101/4/412/412000
Felicia rear springs
16 6U6511115A Coil spring     FELICIA
16 005055544 Coil spring     COMBI
16 6U9511115B Coil spring     PRAKTIK
16 6U6511115D Coil spring     "CN","RUS":
FELICIA
16 6U9511115C Coil spring     "CN","RUS":
COMBI
16 6U9511115A Coil spring
for models with
    PRAKTIK
https://www.lllparts.co.uk/catalogs/skoda/CZ/FEL/101/5/511/511000
Kilen and Lesjofors are the same springs, made in the same modern factory in Sweden. Kilen and Lesjofors are the largest manufacturer of aftermarket car springs in Europe. I've listed them below, but there are also many other aftermarket brands that are sold to replace the below three OEM part numbers. Some of the other brands might not be as good quality as Kilen and Lesjofors...and sometimes they won't even be a good match to the original springs...particularly when more than one OEM part number is listed against a particular aftermarket spring.
I've linked to autodoc because that is a useful website for finding out what aftermarket springs are available, but prices are sometimes cheaper on ebay or other online sources.
If you fit 1.6 petrol front springs, the unladen ride height of the front of the car is likely to be higher than standard, ie. a high front end.
Front springs 6U0411105D (for Felicia 1.3 petrol)
Kilen 23102
Lesjofors 4085702
https://www.autodoc.co.uk/car-parts/oem/6u0411105d?supplier[]=253&supplier[]=246
Rear springs 6U6511115A (for Felicia hatchback)
Kilen 63103
Lesjofors 4285703
https://www.autodoc.co.uk/car-parts/oem/6u6511115a?supplier[]=246&supplier[]=253
Rear springs 005055544 (for Felicia estate)
Kilen 63104
Lesjofors 4285704
https://www.autodoc.co.uk/car-parts/oem/005055544?supplier[]=246&supplier[]=253
Edited by Carlston
Bear in mind what you do to the front can affect the rear, front and rear need to balance and compliment each other to keep the car's balance on the road.
9 hours ago, D.FYLAKTOS said:
...Eibach springs 40mm lowering...
The OP is in Ukraine so might want increased ride height rather than lowered ride height.
Perhaps look at fitting over-size tyres to increase the ride height.
If 165/70R13 are currently fitted, consider 175/70R13, 155/80R13, 185/70R13, and 165/80R13.
Outside diameter of tyre
165/70R13 561.2mm
175/70R13 575.2mm (2.5% bigger outside diameter compared to 165/70R13)
155/80R13 578.2mm (3.0% bigger outside diameter compared to 165/70R13)
185/70R13 589.2mm (5.0% bigger outside diameter compared to 165/70R13)
165/80R13 594.2mm (5.9% bigger outside diameter compared to 165/70R13)
Increase in ride height compared to 165/70R13
175/70R13 7mm
155/80R13 8.5mm
185/70R13 14mm
165/80R13 16.5mm
If 175/60R14 are currently fitted, consider 165/65R14, 185/60R14, 175/65R14, 165/70R14, and 185/65R14.
175/60R14 565.6mm
165/65R14 570.1mm (0.8% bigger outside diameter compared to 175/60R14)
185/60R14 577.6mm (2.1% bigger outside diameter compared to 175/60R14)
175/65R14 583.1mm (3.1% bigger outside diameter compared to 175/60R14)
165/70R14 586.6mm (3.7% bigger outside diameter compared to 175/60R14)
185/65R14 596.1mm (5.4% bigger outside diameter compared to 175/60R14)
Increase in ride height compared to 175/60R14
165/65R14 2.25mm
185/60R14 6mm
175/65R14 8.75mm
165/70R14 10.5mm
185/65R14 15.25mm
Out of the above oversize tyres, I would probably go for 175/65R14 fitted to 5Jx14 ET35 4/100 57.1 steel rims from the Citigo although the standard 14" Felicia rims could also be used.
Notice that the below 14" steel rim from the Citigo is very lightweight at under 6kg.
Vredestein Quatrac 5 175/65R14 82T (Euro label D C 69dB) (3PMSF)
https://www.camskill.co.uk/m137b0s7975p134030/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_175_65_R14_82T_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_69dB
Alcar 6795 5Jx14 ET35 4/100 57.1 steel rim (from Citigo) (5.98kg)
ALCAR 6795
https://www.mytyres.co.uk/rims/details?vehicleId=185473867710468708&rimCode=ALCAR6795
Skoda Citigo wheel trims for 5Jx14 ET35 steel rim 1ST071454C (1169CZK is about £38.43 for a set of four)
Sada poklic Indus 14"
https://eshop.skoda-auto.cz/cs_CZ/sada-poklic-indus-14/p/1ST071454C
Edited by Carlston
I have 175/60/14  wheels, Tecnomagnesio with Toyo Proxes tyres.
If 175/60R14 are currently fitted, consider 185/60R14, 175/65R14, 165/70R14, and 185/65R14.
No, i will have false odometer indications and more ''balloon'' effect.
I like Sport driving style in Mountain roads, not interested for travels in Highways only with 80-100Km speed.
If I remember right table in the service manual, the only difference between 1.3 and 1.6 springs is length -  some higher equipped/heavier 1.3s had same springs as 1.6s. the result will be slightly higher ride height with same stiffness.
1.6
 Length [mm]: 362
 Diameter [mm]: 145
 Thickness 1 [mm]: 14
  Weight [kg]: 3,52
1.3
Length [mm]: 340
Diameter [mm]: 146
 Weight [kg]: 2,37
A simple example from the same source, the number are not something ''absolutely'' but you can see a minor difference (front axle).
4 hours ago, D.FYLAKTOS said:
1.6
 Length [mm]: 362
 Diameter [mm]: 145
  Weight [kg]: 3,52
1.3
Length [mm]: 340
Diameter [mm]: 146
 Weight [kg]: 2,37
The Skoda parts catalogue shows that 6U0411105D is the standard front spring for the 1.3 petrol Felicia and 6U0411105E is the standard front spring for the 1.6 petrol Felicia.
The Skoda parts catalogue lists a heavy-duty front spring with OEM part number 6U0411105D for the Felicia 1.3 petrol. This appears to be one weight range higher than the standard Felicia 1.3 petrol front spring, so could be used instead and shouldn't increase the unladen ride height...going by the below KYB RA2955 listing on autodoc.
As well as KYB RA2955, Kilen 23107 and Lesjofors 4085708 should also match OEM part number 6U0411105D.
Often, it's best not to purchase a spring that's sold to replace more than one OEM part number such as KYB RA2057. KYB RA2057 is sold to replace both 6U0411105E and 6U7411105B, and these are two different springs...so KYB RA2057 can't match both of these springs. I suspect it matches 6U0411105E but not 6U7411105B, due to its length of 362mm. However, if you do need a 6U0411105E front spring for a Felicia 1.6 petrol, it would be better to purchase Kilen 23103 or Lesjofors 4085703 because both of these front springs are only sold to replace 6U0411105E and no other OEM part number...so should both be an exact match to this OEM part number.
KYB RA2955 heavy-duty front spring for 1.3 petrol Felicia (matches 6U7411105B)
KYB K-Flex Front Axle, Coil Spring Length: 362mm, Ø: 145mm Spring RA2057 buy
https://www.autodoc.co.uk/car-parts/oem/6u7411105b?supplier[]=253&supplier[]=85&supplier[]=37
Edited by Carlston
1.3 = 340 mm at 2.37 kg
1.6 = 362 mm at 3.52 Kg
The 1.6 spring is only 22 mm longer yet weights another 1.15 kg, the 1.6 spring must be heavier duty or different material than the 1.3 or the figures are wrong.
I think D.FYLAKTOS means 3.61kg for the 1.3 petrol front spring with OEM part number 6U0411105D.
KYB RA2056 front spring for 1.3 petrol (matches 6U0411105D) (3.61kg) (about 7.2 coil turns) (actual photo, not generic)
thumb?id=831307&m=0&n=1&lng=en&rev=94077841
https://www.autodoc.co.uk/kyb/831307
Edited by Carlston
@Carlston what you really want to achieve? What's your vision?
A 1.3 Felicia with higher and stiffer spring than a stock model?
To do with this what? You want to participate in an Off-Road rally?
I would use the softest springs I could, paired with an ARB if you so wish and high profile tyres 175/70/R14
If you want rigid front - 1.3 pickups had similar spring rates to 1.9. the problem is how to get stiffe rear, pickups had different rear axle, hatchback require progressive springs to get stiffer, while keeping original ride height and suspension travel.
Up-down, left-right, nice and easy.
If it's grandpa, traveling only in highway, right lane and 80 km speed why not?
3 minutes ago, D.FYLAKTOS said:
it's grandpa
Exactly for whom the felly is engineered for
  • 6 months later...
if i could i could give you but its for my other felicia sorry
