"My" 100NX - A rubbish piccie
'nuff said. :o LOOK, its getting dark OK.... :D
Tis black
Tis dark blue. :P Unless you're just talking about the general symptoms of "night" :D
a`100nx?????? whats dem like?
Not bad as a runabout while the beloved furby is in for some overhauling. ;)
:rofl: Fair enough mate. Hope it goes well with it, it's gonna be one hell of a project reading through the (several) threads on your PD1xx motor :D
PD1__???? What happened to PD2__? ;)
Actually, I redlined the Nissan for the first time today, and it goes quite well up that end. I just don't like the 80mph = 4000rpm in fifth..... Not used to revs that high when cruising.... :D
Quite grainy, but you can see it a bit more clearer:
Quite grainy' date=' but you can see it a bit more clearer:
[img']http://www.briskoda.net/gallery/files/3/2/0/5/100nx1.jpg[/img]
Not a bad car, at least it has character :thumbup:
Hey james, i'v got some pictures of Paris Hilton that are quite dark... :naughty:
The car is ok It was the recessed headlights they got wrong on the 100nx
Its got a bigger boot than my Fabia too! :eek: well, bigger, but not quite as high. :)
looks kinda funky really
Might take the glass roof bits out for the way home tonight :D:cool:
Send 'em over :D
Indeed, do :D
Jason, just take it easy on the engine, parts are silly expensive. I stupidly ran with no water in the rad and took out the cylinder head, head gasket and ecu. If I had the head skimmed, new gasket and ecu you would've been looking the wrong side of
How did no water in the rad take out the ECU??? :confused:
Confused the hell out of it. I called Nissan and the said take to dealer, which I did, they checked the ECU and even sent it away, but it was unsaveable, couldnt even load the original settings back on.
Send 'em over :D
l got the full vid :P
