Replacing the Fog Lights with the LEDs ones or Adding ones
Hi Guys
I wonder if you could help me...? I have a Skoda Fabia MK2 Sport and was wondering how easy (and if poss) is to replace my FOG lights with the DLRs ones (ideally i would like to have the FOGs when necessary and DRLs)..? Has anyone done this to their car..? Can you please let me know how, post some links for the LED units if you've fitted any and they work...?
If above is too tricky are there any good looking DRL stripe ones that I can fit above the FOG ones..? If someone has done this can you please post some links for the units and let me know how easy it's to fit these.
Any help or advise will be much appreciated.
Thanks, Matty
Edited by Matty FabSport MK2
Thanks for the link George.
My FOG lights work but as I'm not the specialist i want to make sure that when i replace the current fog ones i will be able to use the DRLs during the day as well as FOGs when necessary...:)
Matty
I read the article...Just to let you know i'm not one of those drivers who uses the FOG lights for no reason.
The reason why i want to have the DRLs is besause i travel a lot in Europe and you need to have your lights on in majority of the countries which means that your call will use more fuel and your bulbs won;t last as long as these should...
Matty
I understand you wanting DRL's and now that you have edited the OP, that is clear enough.
Your first Post before Editing just asked about Replacing Fogs with LED's. or Fogs and LED's, that was why i answered the way i did.
Sorry for the confusion,
I would imagine that if you were fitting DRL's to come on Automatically with the ignition during Daytime,
you would have them so that they go out when you switch on your Sidelights and Headlights.
& since you would have dipped beam on with the Fog Lights, the DRL's will be switching off.
http://www.theaa.com/motoring_advice/safety/daytime-running-lights.html
george
george
Yes. I was meant to say DRLSs not LEDs
Does anyone have a link for which lights will fit and also the guide on how to it these...?
Any links...? Suggestions..? Advice..? Please help :)
