How big is your "to do" list?
Well hire's my list of jobs that need doing.
Cam belt kit.
Fit new abs module and clear traction light on dash.
New rear reflector.
Tracking needs doing.
Possible wheel bearing, grumble at 80pmh when turning left.
Turbo oil pipe gasket.
Possibly carnon wrap dash trim, dunno yet.
Enjoy it!
1. Fit new rear hub and paint caliper.
2. Fit water meth.
3. Fit ths engine mounts
4. Fit FMIC.
5. Fit R32 front brakes.
All the above is bought and waiting to be fitted.
2. Fit water meth.
4. Fit FMIC.
Ooh toys!
1. Whiteline rear ARB
2. ICE install
3. G88 discs front and rear (no upsizing due to 16" steels for winter)
4. De-chrome front grill
5. Maxidot and MFW
That will do for now :sun:
fit new plates
fit new coded grille
debadge rear
clean engine bay and fit black fluid caps
stubby aerial
wheel refurb
wrap silver interior grim in gloss black
laminx fogs and wing mirror lights
tint windows from b pillar back
replace cracked wing mirror adjustment grille thing
a set of weitec hicon gts
Leather MFSW & Controller (in my garage loft and awaiting fitting);
New wheel bearing (I hope the VW specialist finds out on Wednesday);
TPMS wiring (all parts in place, just needs soldering to correct wires).
Otherwise, just a wish list of things that may not get done:
RARB;
Remap;
16"/17" alloys;
312mm brake upgrade;
etc.
Always longer than my 'Can afford' list.
In progress.....
DMF and clutch change (Done).
Grooved drilled discs front and rear with green calipers.
New Black 18" BBS CH Style or RS4 Gunmetal rims.
Retrofitted Black leather interior plus door cards.
Front and Rear ARB Powerflex bushes.
New droplinks.
Matte/Gloss or Carbon interior trim wrap.
Unsure about.....
Black grille.
Matte/Gloss or Carbon wrap for Wing Mirrors, Roof and Rear boot spoiler.
The Mrs isn't amused by the way lol!
Ditto...
Nothing major or adventurous!
Clean up the two prongs on the coolant header tank to see if it stops the coolant temp warning light on startup
Go around with the touch up stick
Give the car a good detail, including claying
Source and fit an OEM Stream MP3 unit (or better) to replace the aftermarket Blaupunkt the previous owner fitted
Brake cleaner worked very well on SWMBO's header tank (assuming its 'gunk'/mayo that you are trying to clean out).
Nothing.
Really.. nothing at at all. Everything I wanted to do with this car i've done already.
.. i think. :p
Nothing.
.. i think. :p
Only thing left now then is to change it again :rofl:
In no particular order:
1. Get some Eagle F1 AS2's fitted to the rear of the car (currently have them on front) - I hate the Dunlop Maxx one's that were on there I bought, can feel that they don't grip well and one of the worst rated tyres on TyreReviews!
2. Fit new gearknob - thanks to a forum member here for sending me one!
3. Sort out the stone chips on the front
4. Get my brake pads checked out as when the brakes are hot, they are making the most irritating squeal noise when braking at low speeds!
Edited by Wardy-
DaveB rear brake caliper upgrade
H&R 50mm springs
42DD Shifter bushes
Superpro ALK
S3/Cupra Top Mounts
K04 Turbo Conversion
Sachs/Loba stage 2 Clutch & Flywheel
then I THINK thats me done, lol
Yeah, you're not wrong :)
I'll probably do the grille gloss black to match the mirrors, AKS/44DD shifter bushes when Alex gets some kit into stock, and a k04 when my numbers come up (or more likely stage 1 and pre-cat removal when my warranty has expired).
Well, having owned the Octy for 2 weeks............and In no particular order....
1. 4 Decent tyres (2 on order for Friday - woop!)
2. Clutch & DMF (Darkside I imagine)
3. Powerflex bushes everywhere!
4. Weitecs
5. Remap
6. N/S washer nozzle
7. Tasmanian Devil Tax Disc Holder (surprisingly hard to come by...)
8. New windscreen & therefore DAB aerial thanks to a Transit on the M4 the other day
9. De-chromed (black) grille (thoughts?)
10. See my man and get auto-lock & lock beep turned on
11. Replacement drivers door card
12. New Air-Con compressor & re-gas
13. Tracking
14. Re-paint spoiler
...................got a new house last week too.
#skint
Wheel refurb and alignment
DRLs
Mirror indicator on passenger side mirror as it is fainter than driver side
Replace blank button under stereo with something?
Clean wheel hubs
Purchase two new front shocks as mine leak then fit the new eibach springs i have owned for 3 months
Remap
Fit new pads and paint calipers red again
Try and find a new drivers side doorcard
Loba 4xx turbo
Water meth injection
TD pro race 1.2
Recaro pole position bucket seats
Stasis brake kit
I don't have a "to do list" I just have my basket as a reminder!
Just paint the calipers with the OLD hammerite Skoda green
Change the cat-vision leds to white ones
Fit footwell lighting when it gets here
Easy. :)
No ideas yet?
+1
