Estate Seat Removal
Hi,
I fancy taking the rear seats out of my estate for some fun and was wondering if anyone has done it before and could tell me how ?
Cheers,
Craig
Is this for the type of fun that involves a mattress in the back and a 'lady friend'?!
Hahahaha. Wasn't my initial intention, but could come in handy :p
I assuem it's the same process as the hatchback
lift the front of the seat base, fold whole thing forward, slide 2 metal bars out of the loops in the floor, remove.
repeat for the other base part
pull the release handle of the backrest, pull forward, lay flat, locate hinge on the outer edge of the seat, use flat head screwdriver or similar to push the clip back from off the top of the fixing, lift seat back up and pull upwards, then pull towards the outer door to release from central fixing
repeat for the other side
Ahh sweet!
I'll give it a go tomorrow, much appreciated!
Craig.
What he said is correct
  • 4 months later...
How do you remove the rear centre seatbelt! ?
Unbolt the (17mm?) bolt that anchors it down
