How to remove Central Convenience Unit
Hi guys
Does anybody know how to remove the Central Convenience Unit? I've removed all the trim from under the steering when and I can see the module but I just can't get it to budge. The cables which go into the back of it push up against the bulkhead when I try to remove it.
Appreciate any help.
Anyone? :sweat:
Sounds like something you wee in on long journeys
It is tricky. Take the clutch pedal switch out, that gives you a bit more room. Take the unit out with the bracket. There is a small tag in the middle on the back of it, push that in and slide the unit upwards.
I might book you to swap mine next time I am flying up the M5 - You have officially scared me off completing my full electronic conversion to vRS.... :(
Is that simply a plug out job or whats involved?
Most - if not all - of what you need to know seems to be in here: http://www.briskoda....w-to-with-pics/
Thanks for that! :) I had got to step 8...now to just give step 9 a go.
