Bonnet scoop or BFOFMIC
OK todays dillema
Running twin SMIC's with dual finned cross pipes, but after today I think I'll need more charge cooling, would a bonnet scoop ducted for the Turbo pipework be a feasible option. Or should I get a Seat BFOFMIC
  • Replies 52
  • Views 5k
OK todays dillema
Running twin SMIC's with dual finned cross pipes' date=' but after today I think I'll need more charge cooling, would a bonnet scoop ducted for the Turbo pipework be a feasible option. Or should I get a Seat BFOFMIC[/quote']
Bonnet scoop = Barry
FMIC = Not Barry
Front mount, every time.
FMIC would definitely be the way to go - should fit cleanly, works well and looks good :)
Please can we have some pics of your twin SMIC...
:wrthless:
FMIC = Not Barry
you sure about that? DaveU's FMIC is fully barry!
That's only because he hasn't be ar*ed to put any mesh over the aperture. :D That said I guess the rear wing gives the game away really. ;)
Without cutting the bumper and crash bar you'd wouldn't even know it was there.
Aye Leave bonnet scoops on Scooby's!!!
BFOFMIC is the way forward!!!
BFOFMIC. And if anyone needs any bumper hacking tips to maximise airflow, give me a shout. ;) Should be getting mine today or tomorrow. :thumbup:
Although not sure how BFO it will be, but it will be nice. :D
OK BFOFMIC is the choice, thanks. My kindly next door neighbor reversed into me yesterday so I'll have a spare bumper to practice cutting. Send me a photo Jason.
Next, someone has started a thread re charge coolers, which would be better.
Charge or VBFOFMIC.
FMIC still, unless you have space for a spare water tank under your bonnet ;)
5083.attach
No space under bonnet, I've already got the window bottle under the air intake no space left. As an aside it warms the water and cleans the windows very well.
I'm ignorant as far as charge coolers go but it must just be a water heat exchanger like a boat I presume, I could put a water bottle in each wing once the twin SMIC's were out.
Thanks Andrew, you'll have to give me an idiots guide on how to do that
click go advanced at the bottom of quick reply and then manage attachments and upload it there.
btw are you gettin the fabia rolling roaded today
Mine's a bit more rough around the edges (literally) than the Star's car. :o:D Something else for the bodywork guy to sort out for me. :cool:
Had it done this morning nice cold dense air over at a secret location in Fife. The new tunning box is I'd presume a first on a Diesel (as far as I'm aware ) but very common on Petrols
Figures to be confirmed on a second set of rollers but maxed out 248 & 390.
Couldn't hold these on a sustained basis, settled for 237 and 374. This was at 1.75 bar boost. The new injectors done a grand job. These figures were obtained using my barographic pressure and temp settings. The RR operators pressure readings were 3mbar higher but I thought better to use mine as a standard when I get a second set done elsewhere. :):thumbup:
248BHP!!!!!!!!!!!!!!!!!!!!!!! in a fabia :eek:
Allard have an experimental one at the moment running sustained 260. I think I'll have to get a front mount and try again
any chance of a dyno sheet :thumbup:
  • Administrators
Couldn't hold these on a sustained basis' date=' settled for 237 and 374. This was at 1.75 bar boost. The new injectors done a grand job. These figures were obtained using my barographic pressure and temp settings. The RR operators pressure readings were 3mbar higher but I thought better to use mine as a standard when I get a second set done elsewhere. :):thumbup:[/quote']
Hells bells!
Normally I'd have a short stiff drink at this point. Instead I'm off for a bar of galaxy to enjoy the moment.
Brilliant!
Now to not fall into the oil burners clutches I'll have to get a V8 now...they made me do it love. :D
Nice figures :cool:
WHAT injectors though?! :rofl: Audi V8 TDI ones? Or something a little more special ;)
