My elephant mod attempt, is it ok?
As above really. Just did the elephant mod to Hopfully reduce the oily sludge that builds up in egr, intake ect.
I have routed pipe down near gearbox and put a slit in it to stop it freezing.
Does it look okay?
My pipe goes a little further and actually chucks is out under the car.
But other than that its fine :)
Yeah, seems OK.  Have you done EGR delete?  That's probably 95% of the reason for the oily gunky mess as its burnt diesel fumes being recirculated.
Only egr deleted in software so it doesn't operate. Haven't replaced for a pipe thou. But I am considering
same here Dan, mine comes out and sits on the console bush
I figured the gearbox area is so dirty anyways you wouldn't notice and different lol
it will get messy over time thow I'd extend the pipe a bit down to the floor :)
Looks neat and tidy :)
Sent from my iPhone 5 using Tapatalk.
  • 4 weeks later...
what bung did you use out of interest?
looks good though otherwise
whats the internal diameter then of the bung id need?
cheers for the answers :)
19mm
Lovely. Cheers mate :)
It just 19mm internal hose used from the crank case
ordered the walking stick end and a metre of silicon. will give this a go this week :)
Does anybody know what size the hole is in the intake pipe is. I want to put an alloy bung in it
surely someone has thought of puting a catch tank somewhere for this?
  • 4 months later...
What hosse do i need to order for the crank case.  I have the oil catch can and rubber cap but i have no idea what size hose i need for the crank case.  Thanks.
I used 19mm (internal diameter)
Mine moved a little bit when I was messing around with my turbo and it fed more fumes into the cabin which isn't ideal. Need to move it properly further down now.
I threw mine down the back near the console bush as well.
Just out of curiosity has anyone else noticed doing the " elephant mod " cuts down on smoke at all?
Can't say I noticed, mines really clean on the high map aswell! The smoke underneath the car is quite obvious in colder weather though.
