Yeti paddles
Hello, I have recently mounted a MFSW DSG paddle shift steering wheel in my Yeti -16, and changed the buttons according to the instructions I read about in this forum. The work itself was no problem, and I had  help from a workshop with the VCDS coding.
Everything except the paddles works ok, could it be that I also need to replace the control module ?, And if so, does anyone know a part number?
Regards from Sweden :sun:
  • 2 years later...
I have the same issue on my Yeti 16, I bought the correct switches 5E0 919 719g and fitted them to the VRs wheel. I coded the wheel for DSG paddles. All the buttons work and the horn, but the paddles don’t work. I’ve done this before on my pre-facelift Yeti with no problem, but this one is proving to be a bit tricky.
Ok, please inform me if you find a solution :)
Post an autoscan from VCDS, that should give some clues :)
Well.... I’ve done so to the Swedish agent for VDCS without any luck. They forwarded  the question to Sebastian? In Germany, but i haven’t got any solution yet.....
l can of course post the scan in this forum as well....
It certainly won't hurt to post an autoscan  :)
Here's the full scan:
Wednesday,22,August,2018,19:40:23:28327
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN:                 License Plate:
Mileage: 66970km-41613mi   Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4F 52 55 5F 61
          62 72
VIN: TMBMD75L2G6059219   Mileage: 66970km-41613miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-DFSB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 HQ    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1793
   Revision: 8AH20---
   Coding: 011D0032042701090000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906016HQ 001003
   ROD: EV_ECM20TDI01104L906016HA_001_VN35.rod
   VCID: 7F09FBB7E693DBBC5E-802A
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 016 L    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4904
   Revision: 06253104    Serial number: 00001602160901
   Coding: 0000020
   Shop #: WSC 33361 790 00063
   VCID: 1D35213FC4DF69AC2C-8048
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: 933F400E09270103C90D02E59022809AA1015021
   Shop #: WSC 42200 002 1048576
   VCID: 75E5199FDCAF91EC04-8020
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 CQ    HW: 3T0 907 044 CQ
   Component: Climatronic   H19 0809
   Revision: 00001010
   Coding: 0010000003
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 030177478A7BBF5C3A-8056
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AS    HW: 1K0 937 087 AS
   Component: BCM PQ35  H+  112 0903
   Revision: AC112903
   Coding: 4E000ABFA01BF1C0440800C0110089E44B7000AE626D87608081C7040041
   VCID: 020F72439D61B65431-8056
   Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
   Component: SK356  26  0610
   Coding: 00FFB5
   Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 070316 03  37  0059
   Coding: 02085D
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 10: Park/Steer Assist (J791)       Labels:| 3T0-919-475-V2.clb
   Part No SW: 3T0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0013
   Revision: --------    Serial number: 56231605705004
   Coding: 149307
   ASAM Dataset: EV_EPHVA2CAS46X0000 003001
   ROD: EV_EPHVA2CAS46X0000_002.rod
   VCID: 418DBD4FD0E76D4C68-8014
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    014 0613
   Serial number: 003G5RAVT192
   Coding: 00004E42
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 316DED8F6047FDCC98-8064
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H02 ----
   Serial number: 3572MSME27260957ZZZV
   Crash sensor for side airbag: front passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H02 ----
   Serial number: 3582MSME7F2E1A57ZZZC
   Crash sensor for side airbag: rear: driver side:
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Fahr.H  H02 ----
   Serial number: 3516KSME0015683CZZZO
   Crash sensor for side airbag: rear: passenger side:
   Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Beif.H  H02 ----
   Serial number: 3526KSME3323683CZZZU
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 FL    HW: 5K0 953 569 BD
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20160308300582
   Coding: 1892140000
   Shop #: WSC 48567 001 104857
   ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7BF10FA7F28BC79C72-802E
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5E0 919 719 G    HW: 5E0 919 719 G
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000A1326031013
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5L0 920 940 T    HW: 5L0 920 940 T
   Component: KOMBI         H03 1007
   Serial number: 00000000000000
   Coding: 120E010100
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3D75C1BFAC1F09AC0C-8068
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 BF    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1673
   Revision:   H55       Serial number: 280216F1001890
   Coding: 356333
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00005.02.16
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
   ROD: EV_AllWheelContrHA1VW37X.rod
   VCID: 52AF82030581E6D4C1-8006
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1007
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADF3AE38D114E1499-803E
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000189302363
   Coding: 01150220D001231004
   VCID: 499DA56FE0D7A50CB0-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 71     3501
   Revision: 00H22000
   VCID: 397DD5AF7037358C20-806C
Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1673
   Coding: 050B0500
   VCID: 6FE92BF7BEF3AB3CCE-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Serial number: 0123456789ABCDEFGHIJ
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000189641603
   Coding: 01150020D001231004
   VCID: 489BA06BFBDD5C04AF-801C
Address 55: Headlight Range (J745)       Labels:. 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 F    HW: 7L6 907 357 C
   Component: AFS-ECU       H05 0111
   Revision: --------    Serial number: --------------
   Coding: 03DE00003F000000
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 3779D3978E2323FCD6-8062
   Left_headlamp_power_output_stage:
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Right_headlamp_power_output_stage:
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5L0 035 680 C    HW: 5L0 035 680 C
   Component: MU-S-ND-ER    H22 0245
   Serial number: SKZAZ2S5017377
   Coding: 03130601FF00000011111201008800001F0000C60120810046
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 2A5FFAE34D918E1459-807E
   Data medium:
   Subsystem 1 - Part No SW: 5L0 051 236 AD    HW: -----------
   Component: ECE1 2018  --- 0915
   Serial number: --------------------
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1673
   Coding: 030F1873
   VCID: 71ED2D8FA8C7BDCCD8-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 33061820211491649907
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795 F    HW: 7N0 959 795 E
   Component: TSG HL        H05 0561
   Revision:             Serial number: 0000189271084
   Coding: 010000200001531004
   VCID: 4799A357F6C3537CA6-8012
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
   Component: TSG HR        H05 0561
   Revision:             Serial number: 0000190274413
End-------------------------(Elapsed Time: 03:30)--------------------------
