HELP!
Right guys i fitted second hand turbo to my vrs before fitting checked for play and there wasnt any but fitted and did a 240mile trip to canterbury for work when i got there the car is making a rather loud noise sounds like propellors are catching but it does it all the time not just in boost im hoping its the manifold bolts or exhaust bolts expanded and it the gasket slapping about or a pipe somewere and not the turbo any ideas what it could be guys really starting to lose faith in my car as ive had nothing but problems with it and really thinking of getting rid but dont want to as really wanted it but having too many problems
  • Replies 85
  • Views 5.7k
  • But 4 up at that speed is shocking fair enough on your own we All do it but 4 up you risk your passengers life's just to go fast. its people like you that end up in prison after killing one of your ow
  • No lucky it hasn't When you have friends that have been killed in crash where the driver drives like a tool and thinks he is a good driver then you will realise what an idiot you are !!! For the r
  • Not safe simply have you ever had a blowout ?? Or a full turbo failure throwing oil onto your tyres ? At 130 you buggered !! Okay kill yourself that your prob but to take friends ina car at that sp
Did you prefil turbo with oil and build oil pressure before starting car after it was fitted?
Why did the last fail as 99% turbo fails due to something else being wrong normally oil pickup pipe blocked
Old one failed due to oil pickup nd it has been done and yh turned car over few times before starting properly to get oil circulated its a squeek like aux belt but its not the belt as it like grinding/tapping sound really hard to describe
Sounds like the noise mine made as it let go.  When on boost I am guessing and when off doesnt happen?!?!
Yh it does it all the time boosts great i got 130 4 man up and boot full of camping gear otherday not a problem but its just a horrid noise cant diagnose it but gonna spend full day tmoro in garage on it see what the crack is nd check propellors
Right after inspection my tip pipe wasnt put on properly and now the bracket to bolt it down has broke could that being loose make the noise i can hear?
Or could it be my flexi as its looking black so could be blowing
Help please it wasnt my flexi as i had that done and a back box delete with new tip(sounds awesome).
But the horrid noise is still there it is like the belt squeal with grinding in it anyone else had this problem or know what it could be please really need it sorting or im goin to give up on it and go to another car
Could it be the front wheel bearings
You're not going to get a proper diagnosis on line buddy, just educated guesses. Wheel bearing won't make any noise if the car is stopped. You can check them by jacking up the front and checking for play in the wheels and spinning the wheels and listening for any unhealthy noise.
Sent from my C6603 using Tapatalk 4
Why were you doin 130 4 up with kit?
Could just be a doddgy turbo or tge pickup pipe is blocked again due to too much sealant being used?
Having this problem and still doimg that speed sounds like your ragging it and not very mechanically sympathetic to the car? No offence intended.
Not wheel bearings and dont often hit those speeds it does it while plodding along and oil pick up is fine it hard to describe the noise
Must have been camping somewhere near a private road then? :wonder:
Why do some people still insist on bell-end speed bragging :wall:
I was doing that all last week. Legally and safely. In Germany.
Wind your neck in until you know the full story. If he did it on the m1 then he's a moron.
People need to chill out on here.
Doesnt really matter where he was doing it to me. Matters that he knows there is a problem and was doing it.
Specially with 3 others in the car.
A ton thirty on the m1 is nothing, at night when road is empty and lit up. I personally dont mind someone doing it so long as they slow down when others are around or visibility isnt as good. All about time and place.
Back to trouble tho. Have you disturbed something while fitting?
Any slight smoke or oil use now?
No smoke or oil use and jigger72 were u live ill do it on ur road anytime i did it on empty strech of road in hot sunny day so visibility was great and it was safe could av done more but didnt hit that then slowed down again
Water pump ?
I did think that but wen that went on my leon i had no heating nd coolant temp was all over the place but seems fine as got great heating nd temp stays at 90
Bring it on big man :kiss:
Besides, you'd struggle to get 30 down my road, never mind 130. It's about 600m long, one way, cars parked either side and 3 speed bumps – oh yeah, and loads of kids, mums with pushchairs, elderly folk, etc., so by all means come down and act like a ***** if you want.
PM me and I'll send you my address.
PS 'were' should be 'where'; 'u' is spelt 'you'; 'ill' should be 'I'll'; and 'ur' should be 'your'.
PPS How was your holiday?
I could be mistaken but the strange noise must be the nut behind the wheel !
Nothing to do with the wheels mate it does it if reved at stand still
Pm???? No YOU pm me im not affraid to give it ago at 3am that way no kids or pushchairs about you need to get a grip if you dont like the way i drive or comment or spell then take your computer warrior ass and leave my topic and pick your dummy up. Because im sure you abide by the law everyday and dont speed at all
LOL
unfortunately its not about abiding by the law all the time its about you bragging on a public forum and trying to defend it,  speeding is not too bad but lets face it even 130 is a bit excessive don't you think? in this country at least, no matter where, and trying to be a big man saying you'll give it a go in a residential street is just making yourself look like an even bigger **** than you already have.
no wonder your car is buggered lol
good luck sorting it :)
Lol this is the way all Ash's threads go.
Like i said if u dont lile it dont comment at the end of the day speeding is speeding wether ot by 1mph or 60mph so unless you all stick to the limit at all times dont try having ago at me i put my foot down once and saw a good speed and im sure alot of you have done it at some point. I was not bragging i was simply stating that the turbo is working perfectly fine and i dont believe thats the problem of the noise
Guest
