Fake cable site name removed
Anyone used this company as 80 pounds rather than 200. Any good?
Its a known fake scam site.
Taken from their site:
Our VCDS cables are manufactured by us and are an exact replica of the Ross Tech's cable apart from they can only be used with the supplied versions of VCDS 11.11.3 software. Our software is exactly the same as Ross Tech's version apart from our cables are coded specifically to work with our software. Due to this, do not try to use our cables with any other software (even from Ross Tech) as this can permanently damage the cable.
Very dodgy since Ross Tech make the software and real cables.
proof that you really do get what you pay for!
So Ross Tech the way forward then.
I would say so, Ross Tech will sell you a cable with an obvious premium BUT they will continue to develop software and will also support you with all you need via the Ross Tech Wiki community, I got mine from Ilexa in Cornwall after being recommended by Devonutopia, I have also helped two other Brisky members with some tweaks to make a phone work in an Octy blackline and change the country of origin in a Fabia Monte to Australia so as a large MPH display appears in the centre of the clocks.
 Then I have used this myself to identify and repair lots of faults on my Golf, it really is a valuable tool and with time gets easier and easier to use.
 Worth the money in my opinion.
The highlighted text alone is enough to set alarm-bells ringing!
Perm damage your car more like
:) Thanks for supporting our efforts and not supporting those that would steal our work.
save the hassle and buy a legit cable, i made the mistake of buying a knock off one first time round, dont get me wrong it worked a treat for the first time i used it but came to use it again when i had a problem and it was dead but buy a genuine Rosstech
