breaking mk2 octavia 2.0tdi bkd elegance. candy white.
Ok thank you. Ill have a butchers tomorrow.
yes was nice and cold. err so you just want the fans and the housing they sit in? not the rad? not sure how well it would post but ill see what i can do.wouldn't like to send you my ariel as the radio was a bit cack sound quality wise, not sure if that was at fault but wouldnt want you to waste your time fitting it to find out its crap.
Yeah, don't need the Rad, just as well(the postage would kill me)
Just the compressor and fans/housing. Cheers.
Tapatalk'd from my HTC SXE
Yes the rear bench is available. No logical reason why they wouldn't fit an estate. The bases could do with a wet vac, with the boot taking a hammering it wouldn't shut so some water got in. Ill try and get this done for you.
No rips tears or marks otherwise. Would you be picking up? Do you want the head rests?
Cheers jim
Hi Jim,
thanks for getting back. How much water damage got onto the seats?  Are you able to take photos?
Also, i'm not 100% certain that the estate and hatchback seats are interchangeable so i'm going to take a closer look next Monday at the Skoda garage when my car's booked in for a service.
If the water damage isn't too bad and your seats would fit an estate, how much would you be looking for, with and without the headrests?
And yes, if it's all a goer, i would arrange to pick them up.
Yes I can, send me your email and ill send you some. Perhaps water damage was the wrong description, there's just a couple of faint lines from where a bit of water has got under the bench, you'll see from the pics that they are in good nick. I'd do the whole lot for £80.
Re fan housing, I prob won't know until weds, daughters bday tomorrow so plenty on already.
Hi Jim. When you say you are selling the dash as a whole, do you also mean the felt cover under the glovebox which is fixed on with two plastic screws to hide the underside of the dash and provide access to the pollen filter? If not and you will separate can you give me a price posted to South Wales please?
Adam
PM sent.
Any movement on the EGR? Maybe a cheeky £30 all in posted? Also do you have the tandem fuel pump?
Jim as an Elegance, did it have auto lights and if so is the switch available?
Yeah I can do £30 posted on the egr. Pm me your details. By tandem which one do you mean? I have the in tank and the high pressure on from the side of the engine.
No auto lights fitted sorry.
Never did find that boot hook.
Yes the high pressure is the one I meant. Dont worry about that for now though I just go for the EGR. Will send PM now, thanks
