No bend lighting (AFS) function
2 minutes ago, jaselliott said:
where is the headlight levelling sensor on tne skoda superb mark 2. i went out last night and they were pointing down.is trere a way to reset them.Jim
You have two level sensors, they should be on the passenger side front and rear suspension.
It'll depend what caused them to point down to whether it's possible to reset them, you might need to fix the fault first ;)
  • Replies 54
  • Views 73.8k
  • I think I might be able to answer this one. It sounds like you have a faulty sensor. This happened to my Superb a couple of months ago and the dealer found water in one of the headlamp levelling senso
  • I think you need to stop spamming any 'headlight' related thread.   You've been given some good solid advice on what you need to do on several other threads, we all want to help but you need
  • The answer, which has been pointed out to you a few times by now, is that you need to get a diagnostic scan done on the AFS control module to see what the fault is. There is unlikely to be a quick  an
how do you reset them
Use diagnostic equipment such as VCDS to clear the fault codes...
If the faults are valid and come back, fix whatever is causing them then clear them again. Depending what you needed to do, you may need to run basic settings which also requires diagnostic equipment.
thank you
4 minutes ago, jaselliott said:
thank you
Do what @langers2k
said above. There's no shortcut or quick fix option here.
