HELP ! superb not responding to ignition
Seeking advice from BRISKODA comunity ....
-my skoda superb's not starting to ignition. -the display's telling me to move the automatic lever to P/N when its actually parked. -a mechanic came by and jumpstarted it directly. - drove the car down to dealership and then at the service station they told me it was a problem with the ignition switch and it was promptly replaced. - the car was starting normally after for like 2 days and now the problem is back !!
- the saga - i sit in my car and then turn on the ignition with the key and the display shows the same message. - i call up the dealer and he says he needs to check it once again - but service station for me is a 3 hour drive ! so need your opinions so that i can discuss with the technician above the problem . . help much appreciated !
Sounds more likely to be DSG box sensor not sensing its in P position when it is.
the indicator does show that its in P . . and the engines starting maybe on the 6th or 7th try ! . . the ride after that is smooth without any problem tho . .
