brake warning light
2002 1.9 SDI octy brake warning light comes on randomly had brakes checked all superb checked fluids and are full, doesn't happen under braking. Just sometimes when I start the engine and also when driving, no flashing just solid wierd
Its either handbrake warning or fluid warning. If the handbrake is off properly, and your fluid is at the right level, you'll probably be looking at either the handbrake switch or fluid level sensor.
Sent from Tapatalk 2
So sounds not to serious will deffo go look at it after the rains buggered off thanks for your reply
Just to be clear, you're talking about the red brake warning light yeah? Not the ABS light?
Found this the light found it on Google images, ( image from Audi but same as mine)
Edited by SKODYFREAKZ
If you have the pad wear sensors on the front ns wheel it could be a loose connection of that, worth a look and an easy fix
Looks like I am gunna have to only owned the thing 2 weeks second issue with the brakes
Easy fixes all of these things!
Either top up fluid
Put new handbrake switch in
Cut out the cr@py join in the pad wear wires and replace
Even if you did all of this it'd only take 3-4 hours tops
Thank for ideas
That light is for pad wear. If the pads are good, fit new warning wires. Nearside front and offside rear
Had the same thing turned out to be rear left rear caliper sticking
Edited by GAZ911
Thanks guys
I had this on another make of car and it was the wire for a brake wear sensor had rubbed against a sharp edge and was intermittently connecting to ground as I went over bumps or cornered.
