skoda fabia mk2 vrs soundproofing guide
On 10/1/2013 at 17:10, mrburdon123 said:
Boot fully lined with underlay. The carpet still sits flat
1_zps62307764.jpg?t=1380622806
First panel to remove is the middle one. Pull carpet up to reveal two plastic nuts
2_zpse6e22b23.jpg?t=1380622807
The nuts aren’t tight so just used pliers to get it going then unscrewed by hand
3_zpsc8068ca1.jpg?t=1380622810
There are two plastic plugs at each end on the centre trim, pull the centre pin out first then the plug can be removed.
4_zps1b9db8a4.jpg?t=1380622813
Pull the bottom of the trim out and up to pop the spring clips out from the slots in the chassis
6_zps6193efef.jpg?t=1380622817
Rear pillar trims require removal to gain access to rear arch trim bolts. Pull from rear first, again metal spring clips hold it on
7_zps35ee2211.jpg?t=1380622819
Pull down from the top corner nearest the window, moving down to the bottom corner. Add a bit of underlay when refitting.
8_zps9b00878c.jpg?t=1380622821
To get the side trims out
Bottom left to top right -
T25
T10
Flat head
Light (one end needs to come out before the other)
T25
T30
T25
9_zpsaa4d534a.jpg?t=1380622823
Bottom corner of back seats have another plug to pop out
10_zpsa42c7d93.jpg?t=1380622826
Once all the screws are removed, pull the trim away from the back. Pad out behind the trim with underlay filling all the gaps so it pushes against the trim but not so much it doesn’t allow the trim to sit back square to the screw holes. Now the trims are off, put the underlay down over the whole boot.
11_zpscdfb8eb9.jpg?t=1380622828
Pop the back panel off, there is a T25 screw near the pull handle which needs removing, pad out with underlay.
12_zps219e2a9d.jpg?t=1380622830
Door trims. There are two T30 nuts under the door handle cover, the cover will just pull off. There is a  T10 at the bottom of the door card, two T10s for the front cards.
13_zps89736dde.jpg?t=1380622833
To remove the rear winders, set at 7 or 5 and pull the spacer out.
14_zps6a03ac99.jpg?t=1380622836
I ran out of the other underlay so got a bit more stuff from BnQ and with spray adhesive stuck it to the door cards.
15_zps025d77a2.jpg?t=1380622839
Bit more underlay added to the door.
16_zps7efc7717.jpg?t=1380622840
To get the underlay under over the floor pan, the side trims and front seats need taking out. Front seats are on 4 M10 spline bolts.
Pull the pillar trim away, its on metal spring clips again. Dont take the top one out as its got an air bag under it.
17_zps2d1290ad.jpg?t=1380622844
Pull the base of the trim up. Its got three spring clips at the bottom and one guide pin.
18_zpsc3946d95.jpg?t=1380622845
When re fitting, add a strip of underlay behind the trim.
19_zps2be44093.jpg?t=1380622848
Pull the front sill trip up
20_zps00437e07.jpg?t=1380622852
21_zpsbe5e9f04.jpg?t=1380622853
T25 screw behind the bonnet release. This allows each side of the carpet to be pulled up and more underlay added as one whole strip from under rear seat to under the dashboard.
22_zpsbd1a0b14.jpg?t=1380622854
Didn’t take the seats out again so haven’t got a shot of how the underlay looks with the whole carpet up but you can get the idea.
When putting things back together, here are a few things that help.
Open up the spring clips before re fitting to keep everything tight.
24_zps6a5a50c8.jpg?t=1380622860
25_zps8b65112f.jpg?t=1380622862
If the clips get stuck in the body, pull out with a pair of scissors.
26_zpseac2fd12.jpg?t=1380622864
Hope this guide helps people. I had aready put a load of the underlay in the car before i took these pictures so some of them dont show the full view of the underlay iv added.
If any more info is needed on how i did things just shout up.
It wasnt difficult to get all the trims off but sometimes a good pull was needed. If  any of the trims wont budge at all theres a good chance that youve missed a screw somewhere.
Cheers for reading
Can anyone reupload the pictures?
  • Replies 52
  • Views 20k
  • Boot fully lined with underlay. The carpet still sits flat     First panel to remove is the middle one. Pull carpet up to reveal two plastic nuts     The nuts aren’t tight so just used plier
  • Yesterday, i did some soundproofing on my Fabia Montecarlo - I must say that this car dosen't have any isolation in the doors.   For me it was more for the sound and not for noise from outside the c
  • I read a guide ages ago that suggested you should put the - excuse the description - "stick on foil stuff" first, and then put some of the "carpet underlay" type stuff on after.   Doing that gives y
Same question as above.
I posted a thread recently (about 3mths ago) with my soundproofing.  Wasn’t too difficult, although the side panels on the combi are a bit of a PITA.
