AIRTEC inter coolers kit
Does something like this fit easily into a standard VRS, or do you need to do some finnicking to get it to fit / replace the standard IC ?
If your VRS is standard then what's the reasoning behind fitting an updated intercooler?
It would replace the standard intercooler.
Some bumper and crash bar hacking is required. But arguably not necessary to replace if rest of car is standard. You can always start with the pikey mod first
You'll get a good run through the gears before it heat soaks on stock smic , with a massive ic you'll not get heat soak but introduce a little lag.
